11-12-2021, 01:03 PM
Good UCA recommendation
I’m starting to accumulate parts to lift my TRDP for when the stock tires give out. Some type of wheel on 34 inch tires, toytec 2-2.5 inch lift (spacer front, new spring rear system).
I’d like to install some aftermarket UCAs at the same time.
Looking for recommendations on a solid pair to use.
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
11-12-2021, 01:12 PM
Real Name: Danny
Real Name: Danny
ICON Delta joint UCA
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
11-12-2021, 01:49 PM
SPC makes awesome arms and other products. Spc 25480
11-12-2021, 03:07 PM
JBA Off-road UCAs
Home page
Solid UCAs… excellent customer service and follow up.
11-12-2021, 03:49 PM
I like the Ironman Pro-forge. Look good, good amount of caster, and very low maintenance (don't have to grease the bushings every 3-5k miles).
Sent from my SM-G965U using Tapatalk
11-12-2021, 07:59 PM
there are so many good ones out there, so get what you like.
11-12-2021, 08:30 PM
^^^ this
Depending on how you use the rig, you may also want to consider serviceability (ie greasing, uniballs vs ball joints, etc)
11-12-2021, 11:43 PM
I don't know, mine weren't really awesome. Craptastic balljoints failed in a few thousand miles. They also had a nasty habit of breaking welds back when they were tube construction. Interesting that they have gone to a forging - it's massive overkill for the application and going to be much heavier than needed, but way better than broken welds.
After trashing my SPCs, I've done about 250k miles on TCs without issues, other than the obvious - squeaky poly bushings and constant uniball replacements. The cromo construction (4140, IIRC) of the TCs are also massive overkill for the application, but at least they aren't heavy, but they are expensive.
11-13-2021, 12:22 PM
Real Name: Jared
Real Name: Jared
UCAs
JBA Offroad!
Outstanding customer service, built very well, lifetime warranty.
*'16 Trail - JBA UCAs, Toytec BL, Dobinsons FR, Radflo LT Rear, (~3.5F/4R total lift) 285/70 (/75s next), mix of HeftyFab/SSO steel goodies
11-13-2021, 03:02 PM
I don’t want to be regreasing stuff every few thousand miles. I’m looking for a “set it and forget it” set of UCAs that I can have installed and not have to think about.
I’m doing UCAs to avoid having my CV boots torn due to the lift. I had a 3 inch toytec lift on my old 3rd Gen with stock UCAs and ended up having torn boots
11-13-2021, 03:08 PM
Aren’t Dobinson UCAs maintenance free? How do they hold up over the years and is the built in caster enough for a 3” lift?
Thanks
11-14-2021, 10:04 AM
what? UCA's have nothing to do with your CV boots
11-14-2021, 11:15 AM
So, UCAs will have little to do with that if any it will allow your alignment angles to be at or closer to specification . The biggest thing to help your c.v shafts with a lift will be a differential drop kit, this lessens the stress on your cv shafts and flex on the boots.
11-18-2021, 12:59 PM
I have these and have tortured them as much as I can for 2 years. Love them and every shop I've had my 4runner in has said they are worth every penny.
