Old 11-17-2021, 12:00 AM #1
Dreaded_Marauder Dreaded_Marauder is offline
Dreaded_Marauder is on a distinguished road
What a difference 2 degrees of castor makes
Being the mechanic I am I’ve seen lots of aftermarket control arms wear out very prematurely. I have never once recommended anyone with a Toyota ifs to get a pair. The price is extreme and they wear out before the factory does on the regular. You can get away with not installing a set really with no problem on a lifted application.
Now with that being said, I just installed a set of Icon tubular delta joint upper control arms on my 2018 TRDOR. I’ve got just over 68,000 miles and about 67,700 have been with it lifted on Bilstein 5100’s. For about 40,000 miles I ran them at 1.75” in the front and a 1” rear spacer first and then changed out for rear 1” springs. About 28,000 miles ago I brought the front up to 2.5 and changed the rear springs for bilstein 400lb 1.5”.
I am obsessed with this vehicle and have always maintained it and driven it with care. Being a mechanic with an alignment rack I’ve also aligned the damn thing about every 2-3 months. Once “Wayne” reached his final form, with the full 2.5 lift, I noticed the rear thrust angle was off about .2 degrees. So I bought an adjustable rear panhard to bring it dead straight again. My front specs were now out of factory tolerance at about 2.1-2.3 degrees of caster with .2-3 positive camber to give me a tad more caster. That’s all I could get.
I always thought the flighty feeling on the freeway was just the nature of the beast with being on 33’s, lifted 2.5”, running a roof top tent, drawers, and all the gear in the back. Now that I’ve had these installed, and I’m sitting at 4.3-4.5 degrees of caster and 0 camber, I can unequivocally tell everyone that will listen that upper control arms that correct geometry are needed once you run out of adjustment range. It makes the ride so much more comfortable since I’m not correcting the vehicle every bump I hit. The steering wheel feels heavier now in the best way possible. I’m enjoying the commute through construction on the freeway these past few mornings more and I’m now trying to find the rough parts to feel the difference.
If you made it this far I applaud you. The long and short of it is, do it. I have become a believer and will always add these to a suspension package when warranted. Btw, I bought these used with worn joints and rebuilt them for $500. Was I willing to pay $850 for these new, no sir. But here’s to learning and hoping these things make it at least as far as the factory ones did!
Thank you for coming to my TED talk.
What a difference 2 degrees of castor makes-747aaed4-02fe-4931-bc31-a63101ab1fa7-jpg
Dreaded_Marauder is offline   Reply With QuoteReply With Quote
Old 11-17-2021, 12:13 AM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
you should get a EIMKEITH (PCK) panhard correction kit, if you are really serious about centering your rear axle though out its entire range of motion, and not just at its static height. The rear adjustable panhard bar is just a bandaid fix.
Old 11-17-2021, 09:36 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Good to hear of your results from someone who can verify the results with the numbers and the feel.
Old 11-17-2021, 09:56 AM #4
1.5" lift though. think its worth it? i'm stock panhard and no PCK with 1.5" rear lift. ive been on the fence about adding the PCK. the truck handles fantastic.
Old 11-17-2021, 04:56 PM #5
mrblah's Avatar
mrblah's Avatar
If it doesn't bother you, then probably not.
I'm OCD and had these three symptoms:
1. Visible and noticeable axle shift: Taking a measuring tape and measure from frame to outer tire tread on both rear wheel wells. I was off 1/2 to 3/4 of a inch at a 3 inch rear lift towards passenger side. With -negative offset wheels, its very noticeable. This bothered me the most. I'm sure 1/2 to 3/4 of a inch wouldn't really cause alot of axle/drivetrain bind, but it couldn't be good either.
2. High speed rear bump steer on the freeway (butt wiggle). This wasn't fun.
3. Offroading, For me, my rear end wanted to fish tail ALOT in 4 hi on loose sand, so i knew my vehicle wasn't tracking straight. Most people, use the PCK to keep their driveline from hitting the gas tank skid at full stuff. I havent experienced that yet.
There are no negatives other than finding a welder. Easy to install too. Only need to take the driverside rear tire off and jack it up to weld. Don't have to buy a expensive adjustable rear track bar (which i also have).
Old 11-17-2021, 07:28 PM #6
yea i have no symptoms. i also have a welder in the garage so its been on my mind to install just for the fun aspect
Old 11-17-2021, 07:48 PM #7
mrblah's Avatar
mrblah's Avatar
If you got a welder, i would definitely do it.
My buddy also installed a PCK at the same time i did, and like yourself, he was asymptomatic before the install. After the install, he said his rear end feels better but can't say why. Probably rear end feels more planted in general.
It's kind of like upgrading your rear upper and lower links. It's hard to quantify the improvement, but your ass and your spine will definitely feel a qualitative improvement.
I think i mentioned in the past, the PCK made me realize how big of a waste of money my adjustable panhard bar was...lol.
Old 11-18-2021, 01:59 AM #8
"feeling planted"" is such an underrated feeling unless you've felt the improvement. my experience is with traction bars on my titan. HUGE difference. So now i want this. right now. lol.
Old 11-18-2021, 02:13 AM #9
Jeremy556's Avatar
Jeremy556's Avatar
I am no 4 link suspension expert, by any means, but I don't see how this would benefit most 5th gen lifted 4runners, unless you are extending the bump stops and using longer travel rear shocks...
Old 11-18-2021, 04:27 AM #10
mrblah's Avatar
mrblah's Avatar
it is definitely something i didn't need, until i needed it.
My buddy is alot smarter than me and decided to retroactively install it, so he doesn't have to experience all the above IF it were to occur. However, I had to ask him what he thinks of the PCK in his current setup... He says he likes it alot.
This is one of those mods, where you have to drive it, and then you will say "okay I get it now".
Old 11-18-2021, 04:38 AM #11
mrblah's Avatar
mrblah's Avatar
i love my adjustable upper and lower links.
To everyone else:
Is it worth it? YES. Is it necessary? NO. Would I purchase them again? YES.
On my daily commute, my rear end feels as if its floating, or non-existent. Offroading, on the washboards, it just glides over them because the rear suspension will allow the springs and shocks to load and unload even quicker due to lack of binding caused by OEM bushings.
At the same time, i think my aftermarket upper/lower rear links did make the off center axle symptoms way more apparent (fishtailing in 4hi) until i fixed it with a PCK.
Only thing i hate about them is the one i bought has a huge jam nut on the johnny joint end. If it gets loose just by a little bit...its clunk galore. I had to apply loctite and also apply a massive amount of torque to it to keep it from getting loose. Its just one more thing to keep an eye on.
Old 11-18-2021, 01:00 PM #12
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
"Binding " caused by OEM bushings I think is the key here and also in the front.
Replace your UCA/LCA and rear upper/lower arms with good aftermarket bushings like Super Pro and I think you will notice a real difference in "feel".
degrees , factory , i’m , i’ve , rear
What 20 yrs difference makes in interior 2000se 3rd gen T4Rs 31 09-22-2021 03:20 PM
Too Much Castor? jpaws 5th gen T4Rs 5 03-08-2019 06:06 PM
5 lbs of air makes a difference gaber6 4th Gen T4Rs 19 01-17-2019 03:21 PM
Castor alignment off? NathanOfSeattle 3rd gen T4Rs 6 06-20-2012 05:25 PM
