Old 11-27-2021, 03:17 AM #1
boodabill's Avatar
boodabill boodabill is offline
boodabill is on a distinguished road
boodabill's Avatar
TRD Shock Upgrade
Hola from Baja, everyone. I recently upgraded my OEM shocks on my 2014 Trail Edition to TRDs, the Fox kit. I love the shocks, makes a world of difference down here, but the steering seems a little stiffer. I don’t always trust the mechanics down here so I’m wondering what people think.
By the way the rig is still crushing it, not a single buzz or click yet.
Gracias in advance.
2014 Trail Premium, KDSS, Dual Odyssey Batteries, Wrangler NW Power Dual Battery Kit, BFG AT KO2 Baja Champions, LED Fog lights, Eclipse Sun Shade...
boodabill is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 09:04 AM #2
osugsxr osugsxr is offline
Gracias in advance.
get an alignment , ride should be firmer but shouldnt have an effect on steering
Old 11-28-2021, 12:39 PM #3
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
Do the TRD Fox shocks require the frequent rebuild as the high end Fox shocks?
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 11-28-2021, 10:20 PM #4
nwebb01's Avatar
nwebb01 nwebb01 is offline
nwebb01 is on a distinguished road
nwebb01's Avatar
How did you get them? I thought you couldn't purchase them from Toyota?
Sent from my Pixel 3 XL using Tapatalk
nwebb01 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 01:26 PM #5
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
They shouldn't need frequent maintenance. The biggest issue on the higher end stuff is the use of spherical bearings - aka uniballs or spherical bushings. They're not very long lasting in the dirt because they're not sealed and they have a very thin layer of plastic that provides the low friction surface. Dirt and grit + thin plastic film = short lifespan. That's the primary reason I have to pull my shocks out every 1-2 years. They're cheap ~ $10 each and there's 2 on each shock. So it's not a big expense, but it is an afternoon of time. And there's almost always something seized on the hardware that I have to either use a torch or a cutoff disc to remove and then replace. It's never as easy as it seems like it should be.
I've never *needed* to do any servicing internally. I have replaced the shock oil, but never had a valve go bad or a seal go bad. And that probably wasn't necessary.
The OEM fox setup uses rubber bushings. IMO rubber is better in many ways. The most important in this case is that it doesn't wear out for a very long time. And they don't use remote reservoirs. Unless a wiper seal goes out, they're probably a lifetime sort of shock.
Between the two - I'd take the OEM bypass shocks over my FOX 2.5s for my personal use. They weren't on the market in 2015 when I setup my 4Runner suspension. If I were buying today - I'd look for something with rubber eyelet bushings not spherical bearings as a pretty important feature if I didn't want the maintenance.
Jetboy is online now   Reply With QuoteReply With Quote
Old 11-29-2021, 09:38 PM #6
lets find someone to build us retrofit kits. heck delrin is amazing, why not make bushings with that. people use it for LCA bushings already.
Old 11-30-2021, 01:34 AM #7
GT0neX GT0neX is offline
GT0neX is on a distinguished road
I could be mistaken but I understood that a rebuild is recommended at around 50k miles, similar to the Fox shocks on the Ford Raptor.
Sent from my SM-N975U1 using Tapatalk
GT0neX is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 03:29 AM #8
thatgreen4LR thatgreen4LR is offline
thatgreen4LR is on a distinguished road
isn't delrin super rigid? it is best when it comes to holding things together but rubber is better for less vibration I think
thatgreen4LR is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 10:58 AM #9
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Yes. From my experience, nothing beats a quality rubber bushing in regards to durability, longevity, and ride quality. It's why OEMs (even the TRD Fox Shocks) are always all rubber or polyurethane. However, Fox uses what they use for a reason and that's overall racing performance, more fluid movement of the joint, etc. If Toyota used a flex joint, spherical ball, etc. on the TRD Pro shocks they'd be coming in to the dealer for rebuilds constantly and have a lot of upset customers.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 07:44 PM #10
i'm fine with feedback in the cab. i dont even notice the spherical bearings on my kings TBH.
delrin is self lubircating as well.
Old 12-01-2021, 03:29 AM #11
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
To the OP question, if the TRD shocks provided some lift, then the caster angle is affected and change in caster will affect steering wheel feel. That said, lift will push caster toward smaller numbers which makes wheel feedback lighter and that seems to be the opposite that OP is reporting.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 12-01-2021, 09:38 AM #12
yea i'm wondering if the shop aligned it for him and put it in specs the forums call for, which is more castor. its different, but better
Old 12-01-2021, 06:29 PM #13
Jetboy's Avatar
Jetboy's Avatar
If I wasn't so busy lately I'd be working on this exact issue. My thought was to try to find an OEM rubber bushing that would fit the LCA mounting bolt and then machine the lower eyelet to fit. I have a CNC mill that I could machine mine if I built some type of a holder for it to clamp it down while it cut. But I haven't had time to do it.
I think the physical space in the OEM eyelet area is probably too small for something like a delrin bushing. Not saying it's impossible, but that's the biggest hurdle to a rubber bushing too. The COM10 size spherical bushing used is just really small and has a very high load capacity (it's just not very durable in the environment we're using it). So I'm not sure what it would take to find something that is strong enough for the loads, but also small enough to fit physically in the shock without machining it out to a larger size.
I'd love to have an easy direct swap though. Even a sealed bushing would go a long way I'd think. Just keeping the dirt and dust out would probably double the lifespan.
Old 12-01-2021, 09:04 PM #14
cut the bottom mount off the OEM fox units. tap it to match the threads on the king/ fox units, thread said mount to the king/fox units
Old 12-01-2021, 09:46 PM #15
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough
I think they are garbage. I've had three replaced already under warranty and am now waiting on another two to come in to get those replaced. And my off roading consists or riding in sand. Can't imagine doing any type of rock crawling.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
i’m , people , shocks , trd , wondering
Overlanding Shock Upgrade Questions jambalayas 5th gen T4Rs 20 01-07-2020 01:59 PM
Shock upgrade, now vsc, track and abs light all on. Chewy204 4th Gen T4Rs 6 04-29-2019 08:05 PM
Strut/shock upgrade svaero 3rd gen T4Rs 7 03-21-2016 05:27 PM
??? Totally Confused about Strut/Shock/Spring Upgrade Trekerjohn 3rd gen T4Rs 35 11-03-2015 05:14 PM
2000 Ltd shock replacement/upgrade options dendrologic 3rd gen T4Rs 1 05-17-2014 07:40 PM
