Old 11-28-2021, 06:46 PM #1
GrayFox7 GrayFox7 is offline
GrayFox7 is on a distinguished road
Driveshaft replacement clunk
Hello everyone! I am wondering which drive shaft I would need to replace on my 2010 4runner to get rid of the clunk for good. I am tired of greasing it all the time. I think the 2016+ 4runners it was fixed so maybe that drive shaft or the Lexus GX one? I’ve seen some topics on this but can’t figure out an exact part number. Any help with this would be appreciated!
GrayFox7 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 02:46 PM #2
Bump
Old 11-29-2021, 02:54 PM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
is your 2010 part time 4WD?
<<<< is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 05:47 PM #4
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
If it’s the mule kick sensation when you come to a complete stop it’s most likely your rear slip yoke running dry. Grease it up and it should go away
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 08:36 PM #5
Ascole Ascole is offline
Ascole will become famous soon enough
Toyota issues "fix" for axle wrap / driveshaft clunky-thumpy
If you look at the 1st post, the photo of the TSB shows the replacement part number as 37110-35A90. I’d read through that thread just to make sure.
I have the same issue and am contemplating replacing as well, it drives me absolutely crazy. And yes, I grease all 6 zero fittings on a monthly basis.
Ascole is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 08:49 PM #6
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Originally Posted by Ascole View Post
... I have the same issue and am contemplating replacing as well, it drives me absolutely crazy. And yes, I grease all 6 zero fittings on a monthly basis ...
I'm wondering if the slip joint has too much grease in it. I think I would remove the grease zerk, wrap something around the driveshaft to catch grease, drive over deep dips, and then check for ejected grease.
Has anyone disassembled a slip joint to see why the slip joint produces clunking?
DougR is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 09:15 PM #7
I grease until all old grease weeps out, remove zerk fittings and bounce on the back of my car and wipe up all the excess grease…I do this every time.
Clunk goes away for a few days and then slowly comes back. I’ve also tried multiple different types of grease as well but nothing really works.
Old 12-01-2021, 12:00 PM #8
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I got mine replaced under warranty. The part number is the one Ascole spec’d.
Pics in the same thread. No issues since replacement.
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-02-2021, 04:00 PM #9
Yes it is.
Old 12-03-2021, 11:59 AM #10
Is that the front or the rear?
Old 12-03-2021, 12:00 PM #11
Yes it is very annoying haha. Thank you everyone so much!
Old 12-03-2021, 08:19 PM #12
Xtremluck's Avatar
Xtremluck's Avatar
Im guessing you were still within your drivetrain warranty when you did this?
Old 12-03-2021, 11:00 PM #13
1000MPH's Avatar
1000MPH's Avatar
Yes, that’s the rear one. It’s the one that clunks as far as I know.
Yeah, within 18 months of purchase. The clunk started around 10k, I took it in for my 2nd free oil change (early 2010’s spec’d 5,000 OCI), asked them to make sure to grease the Zerks. They didn’t do this as I saw they were still sealed with paint, so I went back soon after armed with the TSB.
Old 12-04-2021, 11:32 AM #14
<<<<'s Avatar
<<<<'s Avatar
I've part time 4WD and had your issue with the clunk. I realized putting it in 4WD on dry pavement (I switched 4WD on monthly to keep T-case and front diff lubed) was causing it. I only use 4WD on snow or in mud and no clunk issue anymore. I think front and rear diffs are out of sink on these part time rigs.
clunk , drive , i’ve , lexus , shaft
Clunk gone but how many fittings on the driveshaft on the 07 4X4 V8? Buckfever 4th Gen T4Rs 25 03-24-2016 03:57 PM
How to CAUSE the Driveshaft *Clunk* Jyn 4th Gen T4Rs 40 08-19-2013 03:38 PM
Driveshaft Clunk Thud cj80cruiser 3rd gen T4Rs 17 03-27-2011 09:41 AM
Driveshaft Clunk Sandpiper General Discussions 3 01-06-2011 11:15 AM
Revisiting the driveshaft clunk(At 36,400 ) Buckfever General Discussions 22 07-30-2008 07:26 PM
