09-27-2015, 05:25 PM
Minimalist/stealth offroad bumpers
Figured I would post up and show my bumpers. At some point, I will do a build thread, but for now.....
My goal here was to experiment and not spend a bunch of money or add any extra weight. So far the bumpers have shown to be extremely practical off-road. Much improved approach and departure, with metal protection around all the common scrape points. I also run a skidmark on the rear hitch when offroad.
I designed and cut the rear then had a local shop bend the tubes for the rear and weld them on. I then took some scraps he had and built some long plate brackets and welded on the front corners.
It's all extremely solid.
I plan to really test it out in Moab next month. If the covers end up getting torn up a bit, it should be pretty easy to hide the damage with a rattle can....
09-27-2015, 05:28 PM
Real Name: Corey Jane
Front looks clean. I like it. Do you have plans for the spare?
09-27-2015, 05:33 PM
I love it. Where do I send the money?!
On a related topic, are your quarter panels plasti-dipped? I started doing the same treatment today and only got one side done until I ran out of blue tape. Doh!
09-27-2015, 05:37 PM
Real Name: Justin
Real Name: Justin
That looks really clean @wfo9
What type and size tubing did you use?
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
09-27-2015, 05:38 PM
Best 5th gen bumpers I've seen. Great work!
09-27-2015, 05:43 PM
No... painted. Long term plan was to line-x. For now it's rattle can bed liner in front... and flat black in rear. The rattle can bed liner stuff holds up pretty well to scrapes. But so far I've cleaned every obstacle since putting it on. I'm pretty sure Moab will change that.
09-27-2015, 06:00 PM
Damn looks good man so tucked and clean.
'16 SW T4R Trail With Some Stuff
'14 Mag Grey 4Runner SR5 4x4 NAV Wifes Ride
'13 Iceberg white FJ Cruiser 4x4,Budbuilt skids and Beefy bump out sliders,Boztec diff skid,Metaltech links,Bilstein 5100's,BFG KM2's in 285/70r17 flavor, Mpac side rack,10lb Powertank,5lb Badger,kenwood V71 drilled NMO,Ellis precision Knobs + Some Stuff. (SOLD)
09-27-2015, 06:01 PM
1 and 3/4 DOM. Wall thickness is 1/8. Pretty standard stuff for bumpers...
09-27-2015, 06:12 PM
Spare is staying put for now. Considering a custom aluminum skid for it, but the material is a little pricey and no access to a water jet at the moment.
09-27-2015, 06:22 PM
Thanks. My plan is to start with Plasti-Dip to see if I can tolerate the look (mine is white). Then change to Line-X. Here's my inspiration:
09-27-2015, 06:30 PM
Like! nice work I really dig what you did with the rear.
Note to self, skidmark, funny that is the first time I have seen one. Shows how much I get out with other people.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
09-27-2015, 07:59 PM
Thanks for the compliments guys... It is not the best out there... but i like it and have been pretty pleased so far.
I think it really throws off the jeep folks. I think they believe it is some type of special edition... because man do they stare and look it over. There is a built jeep at every corner here and they always looked very perplexed when I pull up next to them.
09-27-2015, 08:04 PM
Would love to see some detail pics of the front. Its a very clean look overall and works well with the rock rails. Do you have any pics with the front skin off like the pic of the rear?
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
09-27-2015, 08:29 PM
Okki
I have this one I also have a spare aluminum bumper with the crush cans... They are real easy to come by as anyone with an aftermarket plate bumper throws it away.
09-27-2015, 08:54 PM
Real Name: Jeff
Real Name: Jeff
...They are real easy to come by as anyone with an aftermarket plate bumper throws it away.
Hey...I resemble that remark! LOL!
Just to add something meaningful to the thread: in person it looks even better than the photos.
@ wfo9
's remarks about it looking like a special edition are right on the money. I would do this personally (shop that did the rear metal work is only 1.5 miles from my house), but am set on a rear swing out to get the spare out of the way.
Watching his rig on the trail last weekend and you could really tell that his solution tucks things in all the right places. Very very simple and very very elegant execution.
2012 4x4 Limited
4.56 Gears | ARB Lockers F/R | CKMTA12 | Icon ET Remote Resi C/Os w/ 700lb Springs | MT/Icon LT Rear | Rokmen Uniball UCAs | 17x8 -10 Level 8 MK6 | Cooper ATP 285/70/17 | Shrockworks | BruteForce Fab | Engo 10000S | FrontRunner Slimline II | RCI | Weathertech | Scepter | Kenwood TM-V71A
Sold: 2003 4x2 T4R Sport | 1995 Mustang GT | 1987 Jeep XJ Cherokee
