12-03-2021, 07:39 PM
#16
Originally Posted by BobsTrail
Since you have Multi Terrain it can help in 4 Hi, it's better than the built in traction control. It will not drop engine power and will keep all 4 wheel turning while allowing some slip. I run this on most trails, sand and snow with good results.
Find a snowy area and try with and without M/T to see what you feel is best.
I believe in 4H you only have Mud/Sand available as a Multi Terrain setting. The rest you need to be in 4L.
12-04-2021, 09:54 AM
#17
Originally Posted by downshift
I hear you! What's the point of all the cool crawl control and MTS and ATRAC buttons and dials if we don't push and turn them??? They're just sitting there, staring at me, begging to be pushed and turned!
99% of the time I'm in the car there's no opportunity to use any of these. I try to use them when I have the chance.
When I'm in snow, I use 4H and turn on the mud/sand/snow setting in MTS. At least I get to push that button and turn the dial to that setting.
This guy knows what I'm talkin bout! You must be one of those "Hey... I paid extra for this button so damn right I'm gonna push it" people. I am too.
Thanks for the tips. I took her out in the last snowstorm and it does perform much better in the snow in 2wd than 4hi. But 4hi was outstanding for doing donuts!
12-06-2021, 01:11 PM
#18
Another important thing to be aware of in snow is driveshaft bind induced understeer. (This warning does not apply to the Limited unless you have locked your center diff.)
Imagine going down a slippery hill in 4H, approaching a sharp turn. You turn the steering wheel. The outside front tire, because it can't turn as much as it needs to, has to slide across the snow. In a turn, the outside front does most of the work. Since it has lost contact with the snow, you continue straight.
The solution is to go slower. The sharper the turn the slower you're going anyways, so there's that. But it's something to be aware of.
Current: 2017 TRD Off Road with KDSS
Previous: 2003 Sport Edition AWD
Before That: 1993 Pickup, SR5 V6 5MT Extended Cab 4WD
12-06-2021, 02:20 PM
#19
Usually on paved roads I’m in 4hi. Occasionally on logging roads that are very steep I’ll use the crawl control in icy conditions going down hill. I’ve seen some hills very icy and steep, I probably would not have made it with 4 wd of yesterday. In winter I put blizzaks, your bfg’s better than stock but not much better on ice
2018 TRD-ORP Classic Silver w/KDSS
2015 TEP Super White w/KDSS
2010 TE Magnetic Grey (Gone but not forgotten)
2006 SE V-6 (Gone but not forgotten)
1996 SR5 4cyl 5 speed (Gone but not forgotten)
12-09-2021, 01:21 PM
#20
Unfortunately all those cool wiz bang Han Solo settings don't mean squat on the road 99.99% of the time.
Avoid 4wd when traction is good. It can be more harmful than helpful. When the conditions change, snow, ice shift it into 4hi. When they change back then shift back to 2hi. Yes, unfortunately boring but very practical.
Now when you get offroad or the snow gets really deep start asking the wookie This is when it's time to think about 4lo and various settings. If it gets really bad that locking diff is fantastic on the OR or Pro models. Personally I prefer not to use all those traction control gizmos so I can have max wheel spin in deep snow then give it the beans.
2021 ORP with G.Y. UltraTerrains, Bilstein 6112 1.1" & 5100 rear + Eibach coils 1", & ARB Diff Breather, Accessoride remote start.
12-09-2021, 02:22 PM
#21
Limited is where it’s at. H4F.
12-21-2021, 08:38 AM
#22
Originally Posted by Somnospeed
Hey folks,
I'm wondering if anyone would care to share their icy/snowy/blizzard settings. I have a 21 TRD ORP which has about 400x as many settings as my 2008 SR5 did! I have read the manual and what the settings do and such, but I'd really like opinions from those that actually drive these things in the snow.
I upgraded to KO2 tires so that should help better than stock tires. Now I just need to know where to set all the buttons, knobs, and dials!
Thanks!
in snow - 2wd, good tires, and speed control will get you places. youll be fine
ice - pop it in 4hi, youll be fine
stuck - pop it in 4lo + locker, youll be fine
use those fancy ceiling controls all you want, test them out. youll be fine.
12-21-2021, 11:10 AM
#23
Real Name: Grant
Real Name: Grant
On a crowded urban roads just use 4WD high. Drive defensively and the truck will get you home fine. Finally had a chance to use it the other day and its even more planted. No violating laws of physics. Just plain sense.
More snow please. Want to try it in 6 to 10"
12-21-2021, 02:57 PM
#24
Originally Posted by Jeremy556
I'm from Ann Arbor, born at UofM hospital. You're unlikely to need anything other than 2wd hi most of the time, 4wd hi occasionally, 4lo+locker+atrac if you get stuck. Have your friends and family not disowned you for buying a Jap car?
I would be more concerned about rust prevention with how MI pickles the roads.
So was my Grandson on UM move in day a couple of years ago…. What a shit show, haha
12-22-2021, 10:41 AM
#25
This got me thinking, I have a 2014 Trail Edition, I don't know if I've touched any of those knobs since I got the truck home. I think I put it in crawl mode once just to see what would happen, it sounded like it was tearing the transmission apart with the ratcheting action. I know I've only had it in 4Lo once, that paved driveway looked tricky. But that's what happens when you buy a truck based on the hood scoop, wheels and KDSS package.
12-23-2021, 01:35 AM
#26
A few thoughts:
You generally will stop faster on snow and ice in 4hi than 2wd. It's complicated physics, but it's true. If you need the full explanation I can provide when I have some time. You can see that it's true yourself. There's YouTube comparisons as well. So if it's slippery there's a brake distance benefit to 4wd.
The colder it is the better the traction on snow and ice. Coefficient goes up as temp goes down. Slipperiest condition is right near freezing. By 0* F it's about the same as dry gravel roads.
And it's hard to roll a 4runner without a tripping point like a curb or soft shoulder of a road. So try not to hit a curb going sideways - like doing doughnuts in a parking lot. That's how you'll flop on your side..
And you can drive in 4hi anytime you want. Even dry road. It's won't hurt anything. Don't be afraid to put in 4wd wherever you feel like you'll need it. A stretch of dry roads isn't a big deal.
12-23-2021, 12:28 PM
#27
For rust prevention, spray Fluid Film all throughout bottom and inside door panels. I spray it two times a year.
01-06-2022, 01:21 AM
#28
So for those of you in snow country, in general do you drive in snow with Traction on or off or do you just turn it off when going up hills?
01-06-2022, 03:20 AM
#29
I just leave it on unless I’m in a situation where maintaining momentum is important, such as going uphill or going through deep snow.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
01-06-2022, 08:37 AM
#30
I'm probably 30 minutes east of you, with family in your area.
4HI when the roads are totally covered in snow or ice. Then remember proper following distance. The 4HI definitely inspires confidence but its very easy to become overconfident, and that's what puts you in the ditch.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
