i have the same leak but not really dripping. it just gets wet there and dirt accumulates. i thought it was coming from the valve cover or the front cover seal or something. at one point i worked on replacing my power steering high pressure and low pressure hose due to corrosion. a few months later noticed the area is no longer as wet as before so i thought the leak could have been coming between the power steering pump and high pressure hose fitting.
Originally Posted by chipski
An oil leak started right after my last oil change. Today I changed my oil again as well as the serpentine belt so I got to get a good look for the leak. The oil seems to be coming high up on the passenger side in the area of the power steering pump. Any thoughts on what could be the culprit. Timing cover?
Another thing was after I finished I now have a check engine light and the Trac Off light. Coincidence or did I do something?.
2016 with 111k
