Old 12-11-2021, 03:29 PM #1
chipski chipski is offline
chipski is on a distinguished road
Oil leak
An oil leak started right after my last oil change. Today I changed my oil again as well as the serpentine belt so I got to get a good look for the leak. The oil seems to be coming high up on the passenger side in the area of the power steering pump. Any thoughts on what could be the culprit. Timing cover?
Another thing was after I finished I now have a check engine light and the Trac Off light. Coincidence or did I do something?.
2016 with 111k
chipski is offline   Reply With QuoteReply With Quote
Old 12-11-2021, 03:39 PM #2
Relentlesskaizen Relentlesskaizen is offline
Relentlesskaizen is on a distinguished road
My guess on the leak without photos would possibly be the timing cover leaking. As far as the check engine light, could be coincidence but no way to know without the codes.
Relentlesskaizen is offline   Reply With QuoteReply With Quote
Old 12-11-2021, 03:47 PM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
How many miles since the last oil change? How much oil was lost since the last oil change?
I have a 2011 Trail and a seep in the same area. The seep does not run, drip or appear overly wet. Oil level is still full over the last 4000 miles. Therefore, I will leave it alone.
Toyota 1GR-FE Timing Chain Cover re-seal Tips&Tricks - YouTube Go to time 0:25 to see what a timing cover oil leak looks like.
DougR is offline   Reply With QuoteReply With Quote
Old 12-11-2021, 04:25 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
There are oil leak threads and most involve the timing cover or rear main seal. If you have a CEL, then there will be a code (or codes) to read that should help.
Old 12-11-2021, 06:01 PM #5
Read the codes and the wife didn’t screw the gas cap on all the way...
I’ll try to get some pictures of the leak.
Old 12-11-2021, 06:29 PM #6
BigBlueSince82's Avatar
BigBlueSince82 BigBlueSince82 is offline
BigBlueSince82 is on a distinguished road
I have had the same issue for over two years and 60k miles. Just spray it with brake clean once and awhile and it will be hard to notice.
Probably a coincidence with the trac off light. I had this issue once and it was a ABS sensor after I was going a little to hard on the beach.
BigBlueSince82 is offline   Reply With QuoteReply With Quote
Old 12-13-2021, 11:52 AM #7
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i have the same leak but not really dripping. it just gets wet there and dirt accumulates. i thought it was coming from the valve cover or the front cover seal or something. at one point i worked on replacing my power steering high pressure and low pressure hose due to corrosion. a few months later noticed the area is no longer as wet as before so i thought the leak could have been coming between the power steering pump and high pressure hose fitting.
2016 with 111k
4r-4ever is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 08:48 AM #8
That's what I did- sprayed it down and no more oil smell. I checked the other day and it still seems kind of oil free. I'll just keep an eye on it and buy some more brake cleaner
Old 01-27-2022, 10:51 AM #9
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I prefer to use something a little milder than brake clean in my engine bay, like Simple Green or Purple Power and a nylon brush for agitation if you can get to it. Up to you.
1000MPH is offline   Reply With QuoteReply With Quote
leak , light , oil , thoughts , today
**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution chrisbagnell 4th Gen T4Rs 12 03-08-2022 11:58 PM
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
