Old 12-17-2021, 02:56 PM #1
sporty87 sporty87 is offline
sporty87 is on a distinguished road
Problem with brake light.
2010 SR5 4 Runner.
My rear left brake light is intermittent and Toyota says it is a common problem and you need to buy a whole tail light assembly. That is crazy. They bent something to get it to work but say I will need the whole Assembly. Can I just replace the bulb socket as I see that is separate from the housing?
Thanks
2010 SR5 Magnetic Gray - Black leather interior - Rear pull out tray - Bilstein 5100 adjustable front shocks set at 1.750" - Rear 1.125 spacer with rear Bilstein shocks - PRO COMP 7105 (17"x8") wheels - Wade window visors - Honda S2000 short stubby antenna - Westin Fog lights behind lower grill - Husky mud flaps - Husky floor liners - AVS hood deflector - Rear 4Ruunner letters changed to Italic letters - Rocky Road Super Sliders - custom shift knob - Fiam horns -Bypass switch to turn on rear camera whenever I want to.
sporty87 is offline   Reply With QuoteReply With Quote
Old 12-17-2021, 03:31 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
There have been threads on this in the past and most problems are caused by bad crimps in the wires that go to the plugs that connect to the tail light assy. some of those threads have pictures (or at least they did before the photobucket issue). I suppose it's worth a search to see if they can be of help.
You should be able to get to the connector and inspect and repair those connections. I would try that before replacing the assembly; which may not fix the issue as the crimps are on the connector and you would be plugging in the same connector to the new light assy. It's possible the light assy is bad; but I'd check the wiring first, due to the history of problems in that area.
One way to troubleshoot would be to remove the light assy to gain access to the connectors in back. Then wiggle the wires / connectors to see if you can recreate the issue. If so, you will know where the problem is and maybe which wire is bad.
Old 12-17-2021, 08:21 PM #3
Nick B Nick B is offline
Nick B is on a distinguished road
I had the same problem with my 2010 . I replaced the bulb socket ( $21.65 ) and it’s been fine ever since . 5 minutes max repair .
Nick B is offline   Reply With QuoteReply With Quote
Old 12-17-2021, 08:35 PM #4
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Just replace bulb with some LED upgrades (thicker base, so they fit tighter). JDM ASTAR and LASFIT brands both have tighter fitting bulb bases than stock glass bulbs. I have both in use actively right now in my 4Runner.
How disappointing would it be if you bought the new socket and it was just as loose?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 12-17-2021, 09:44 PM #5
a47chuck's Avatar
a47chuck a47chuck is offline
a47chuck will become famous soon enough a47chuck will become famous soon enough
a47chuck's Avatar
UUUH! This sounds like a safety issue. "Known problem?" How long ago was this problem known? Why was there not even service bulletin or a recall?
Just for shits and giggles, I got a recall on my '71 Corolla 1600 for a problem with the automatic choke, which by the way, took a shit, I was tempted to bring it in even though I had modded it with two Weber 40mm DCOE side draft carbs.
‘19 Limited Nightshade, Midnight Black Met, front leaving kit, 265/60R20 BFG KO2’s, fronts tinted to 20%, moonroof to 5%, Magnuson Supercharger
'03 Harley Dyna Superglide Sport
a47chuck is offline   Reply With QuoteReply With Quote
assembly , brake , light , problem , replace
Brake light problem Sgt. Rock 5th gen T4Rs 1 04-06-2019 08:45 PM
brake light problem collin 3rd gen T4Rs 2 09-15-2011 03:06 AM
Brake light problem. Supra725 3rd gen T4Rs 2 05-06-2011 02:12 AM
Brake Light Problem 4RUNR88 3rd gen T4Rs 1 11-04-2006 04:29 AM
Brake light problem STREETDREAMZ Classic T4Rs 4 10-06-2005 03:04 PM
