Old 12-19-2021, 07:49 PM #1
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
4WD Shift Lever
I have not used 4WD for a few months or more. A few days ago went to the local mountains to get some snow time. I have a 2013 Trail with the transfer case lever. In the past it always engaged and disengaged OK. On this trip, it went into 4HI OK, but after a while in a snow area at 30 degrees, I decided to play with 2 HI. The lever moved forward, but did not feel correct, a bit of resistance. It stayed in 4HI. I decided to not mess with it as I needed 4HI to get out of the area. The next day at home and back up to 45 degrees it went into and out of 4HI with no problems. I don't think the front actuator froze up, but was wondering if it was bound up due to lack of use. Maybe I will engage 4HI more often and hope it does not happen again.
While there I turned on M/T and got a good 4 wheel spin a few times and it went where I pointed it. Still enjoying my old 4Runner.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 12:13 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Sometimes, placing the transmission into neutral and letting the truck roll forward or back a bit will help get the gears engaged right.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 12:26 AM #3
yea if its under a load itll resist. i try to time it so i can coast an engage/disengage 4hi.
Old 12-20-2021, 07:55 AM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
sounds typical, especially in colder weather. Like mentioned above, any load will give resistance during the switch. It's a special club to have the lever!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 11:33 AM #5
yeah its great....the constant rattle from wife's crap she leaves resting against it is fantastic
Old 12-20-2021, 12:51 PM #6
eriktp eriktp is offline
eriktp is on a distinguished road
The manual says to try and drive atleast 10miles a month in 4hi to keep the system lubricated
2020 White TRD OR Black TRD Wheels/Ko2s
eriktp is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 01:48 PM #7
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
I second this!
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 02:11 PM #8
BearBio's Avatar
BearBio BearBio is offline
BearBio has a spectacular aura about BearBio has a spectacular aura about
BearBio's Avatar
WE got a total of about 6" this week. About 1-2" last night and snowing this AM. Don't need to but will switch to 4H just to keep it lubed up when I go to strength training in about a 1/2 hour.
BearBio is offline   Reply With QuoteReply With Quote
4hi , area , decided , degrees , lever
5th Gen: 4WD shift lever grinding getting out of 4L Cytronus 5th gen T4Rs 37 08-11-2022 01:09 PM
Shift Lever Bushings Replaced! Lever is now TIGHT! BamaDrewski 3rd gen T4Rs 4 05-26-2018 06:22 PM
Shift lever boot Lego3k1 For Sale: Non-T4R Items 2 09-12-2015 05:07 PM
Automatic Shift Lever dphflytyer 3rd gen T4Rs 2 11-21-2013 11:32 PM
How do you separate a MT shift lever? Vaughn Classic T4Rs 5 07-29-2012 08:32 PM
