Old 12-21-2021, 05:28 AM #1
nyvram's Avatar
nyvram nyvram is offline
nyvram will become famous soon enough
nyvram's Avatar
Guys I'm back!! About to pull trigger on 2015 SR5 and had questions
Yes I know it's probably overpriced given the specs but my 3rd gen was such an amazing vehicle with 400k miles I want another.
I sold my 98 back to the guy I bought it from 10 years earlier! He was happy to have it back even with that mileage.
SR5, 4WD super white cloth 159,000 miles. 27k from local dealer.
Felt the shimmy/pull to the right at 65mph but short test drive so too early to say if it's a flat spot, bad tire or it needs a road force alignment.
What else should i ask about or should I check on it?
Here's a couple pics. I'm in love....again!
Thanks for any advice!
SOLD Red 98 SR5 - 400k miles
NEW Super white 2015 SR5 4WD 20" MOTO METAL wheels, Nitto Grapplers, TRD grill, hidden features mod, MESO LED 2-color cabin light, rubber mats & animal bars COMING SOON: VIOFO A139 front/rear camera hardwire install, new headunit, speaker & tweeter upgrade.
nyvram is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 07:57 AM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Check the underside of the oil filler cap for sludge, look in the oil filler tube with a flashlight for black sludge. Want to make sure oil changes have been done on time. check for rust underneath. Check for oil leak at timing chain cover. Glance at ujoints to make sure they have been lubed and aren't dry. Obviously, ask for the carfax/service history. Shift in and out of 4hi/4lo, use crawl control, check diff lock, etc. Chances are it's all good. Probably was due for a belt and new coolant around 100k, keep that in mind. Check shocks (and KDSS if has) for leakage. All easy checks with a flashlight. Other than that, check the usual stuff. Good luck! Shimmy can be fixed with a good balance and alignment assuming any lift, etc. was done correctly.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 10:18 AM #3
nyvram's Avatar
nyvram's Avatar
Thank you! Also I was under the impression these used timing chains which did not need to be changed every 100k miles like my old 3rd gen 4runner (I put 3 on it).
Old 12-21-2021, 04:03 PM #4
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Your impression is correct. Think he just meant the usual serpentine belt.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 04:25 PM #5
vbprsx's Avatar
vbprsx vbprsx is offline
vbprsx is on a distinguished road
vbprsx's Avatar
Slightly lifted?….can’t tell. Looks like factory rake but a smidge higher overall. May just be the wheels.
‘20 White TRD Venture w/KDSS * 2”/1” Bilstein 5100 * TRD Pro-GR Wheels on Toyo RT Trails * TRD CAI * TRD Exhaust * LASFIT LEDs * AVS Low Pros and Aeroskin * Westin Protraxx * OEM Audio Plus Speakers and Dual 8” JL
RIP "Clifford"
vbprsx is offline   Reply With QuoteReply With Quote
bad , miles , spot , sr5 , tire
About to pull the trigger on a 2015 T4R... need some insight kapp_badbloodz 5th gen T4Rs 52 06-27-2015 09:15 PM
should I pull the trigger....or not? T4Rscott 3rd gen T4Rs 16 04-17-2013 11:30 PM
About to pull the trigger on Radflo 2.5 coils...questions about rear spring setups weeeee 5th gen T4Rs 13 12-03-2012 10:23 PM
Would You Pull the Trigger and Buy this? Perfection 3rd gen T4Rs 24 07-29-2012 12:58 AM
About to pull the trigger!!! Richierollz 4th Gen T4Rs 1 12-30-2010 05:58 PM
