07-10-2012, 07:57 PM
20" Limited tire recommendations
Good evening, first post! I need a little help. I hate the OEM tires that came on this generation 4Runner, and I don't like my options on tirerack. Only 3 choices?? Am I missing something here? Looking for a tire brand with tire life longevity and a smooth quiet and safe ride for my family mostly on Florida roads and for florida type weather.
Any ideas? Don't really care to go down in rim size. Just want to take the old tires off and put the best ones back on the same rim without any customizations.
Thanks for your help.
07-10-2012, 08:40 PM
try the search function! there are a million threads on this topic
2006 4runner SE v8 SOLD
2010 4runner Limited Black (first one in IL!!), husky weather beaters, Defiant Light Bar, PIAA 520 ATP's (converted to 55w HIDS), BFG Rugged Terrain 275/55/R20's, Husky Mud Guards,magna flow 15682, AFE CAI, back up camera switch (factory nav), LED mod, and more to come!!! SOLD
2014+ JGC Summit DIESEL ;)
07-10-2012, 08:41 PM
Do a search! Tons of threads already about tires.
07-10-2012, 09:04 PM
And one more for recommending search function.
2010 Land Rover LR4...soon to be 2013 4runner?
SOLD: 2008 Urban Runner Blizzard Pearl
front skid plate add-on, HID 4300k, Alpine IVA-W505/p1 double-din, Focal 165 KRX2 components, Focal Access 165CA coax, JL Audio HD900/5 5-channel amp, JL Audio 10w3v3 sub
07-10-2012, 09:11 PM
Real Name: Tim
Real Name: Tim
the problem with simply telling him to search is that it fills the forum with this non sense and when people do search all they get is threads like this, or the OP is scared off and never returns for his answer.
now i dont own a 5th gen but 275/55/20 is available in a lot of manufactures and should fit fine. assuming you want to go larger than stock size tire that is...
He's an angel dressed in oilskins; he's a saint in the "Sou'wester,"
He's a pluck as they come, or ever can;
He's a hero born and bred, but it hasn't swelled his head,
For he's just the U.S. Government's hired man.
07-10-2012, 09:31 PM
I have seen several on here go with 275 55 20 to open up more tire options. Here are some things to consider. By going to this size you are basically keeping the tire diameter the same so it won't throw off your speedometer much. The 275 55 20 will have more weight per tire and a larger footprint than the stock one so you will probably have slightly less mpg. The main issue is the limiteds narrow wheel of 7 inches and that most tire manufacturers recommend at least a 7.5 inch wheel for 275 55 20. The Continental CrossContact LX can accomodate the 7 inch wheel. I have no experience with this tire but the reviews on tirerack are very good. It should work well for your Florida seasons and it has a 70,000 mile warranty. The wider footprint alone will look much better than stock imo. Good luck.
07-10-2012, 09:42 PM
Real Name: Tim
Real Name: Tim
you make a good point and it seems the 4Runner forum is way more conscious to this than most other truck forums. however its only .5" we are talking about here, i ran 315's on a 7" wide wheel for 4 years on my 2500HD with zero negative effects other than having to rotate tires like crazy.
of course this is technically dangerous so if you do run tires that wide and say lose the bead and crash…not my problem
07-10-2012, 11:42 PM
The reason for limited options is Toyota made probably the only 20" wheel with 7" width. Most SUV wheels in general, not just 20's are 7.5" and up. So you will technically be going out of spec. Hence why the majority by new wheels to go with their new tire set up. Like myself...
Current - 2015 TRD Pro: Toytec TRD Lift, TRD CAI, KO2 275/70/17, ShrockWorks Sliders Dimpled, Vinyl Wrap Hood, Ellis Precision Shifters, OEM Bug Guard, Factor 55 Hitch, WeatherTech
Had- 2010 Fully Loaded Limited Mag Gray: 275/55/20 Hankook RF10's on 20x9 Matte Black V-Tec Off Road
07-11-2012, 12:16 AM
Real Name: Billy
Real Name: Billy
Go with the 275/55x20 you will be fine!
As for it throwing off your speedo it won't, when I went to 275's it corrected my speedo which was slow by 2mph @ 60 with the OEM tire.
Billy a.k.a. Q-Jake
2011 Limited MGM... ... My Build
07-11-2012, 01:26 AM
Real Name: Danny
Real Name: Danny
See this thread for a lot of similar posts 20 inch wheels on LIMITED
07-11-2012, 01:25 PM
I put the Continental CrossContact LX20 275/55/20's on my LE -- they're recommended to fit a 7" wheel. I like them much more than the OEM poo-poos that Toyota put on - more sure footed ride, handling's slightly better and they look 8 billion times better on the truck.
2015 TuRD Pro -- Attitude "GLITTER" Black
07-11-2012, 02:15 PM
I will be going with the Michelin LTX M/S2 in a 275/55/20 on the stock Limited wheel. I like the look of the wheels, so I'm not interested in replacing the wheels for a more uniform-sized wheel.
I have the Michelin LTX M/S2s on my Avalanche and love them - they are a great tire!
2012 Magnetic Gray Limited 4x4
07-11-2012, 04:04 PM
Curve ball
Thanks for those who replied with actual answers. I am leaning towards maybe the General Grabber UHP's or HTS, or the Continentals Cross Contact LX's .... however, I called my local Toyota dealer and they are telling me that I should put 255 50 20's on. Anyone have experience with those? I was thinking of going with the Hankook Ventus AS RH07's. Thoughts?
07-11-2012, 05:00 PM
Did your dealer give a reason why they recommended 255/50/20's? I'm assuming it might be mpg related, but know this -- I've been running my LX20 275/55/20's for well over 1,000 miles now and my mpg has not changed.
I'll never a run a tire any smaller than 275/55/20 on my T4R for as long as I own it.
07-11-2012, 07:02 PM
The dealer recommending 255 50 20 is a poor choice imo. The tire sidewall would be .8 inches smaller, and the overall diameter would be 1.6 inches shorter. This size would look small and it would make your speedometer way off. When it says you are doing 60mph you are actually doing 57.1mph. I would go to 275 55 20 like others have stated.
I also have the Michelin LTX M/S2 on my 3rd gen and it is a great tire. I only recommended the Continental due to the narrow 7 inch wheel. Sure you could make the Michelin work (minimun wheel width recommended is 7.5), but I would hate to have a tire problem that caused a serious injury to my family or someone else and have some attorney's investigation cause a large lawsuit.
