Old 12-30-2021, 01:07 AM #1
J150-Q8 J150-Q8 is offline
J150-Q8 is on a distinguished road
Timbren Bumpstops + LCA + Spacer
Hey Guys,
I just want to share some info since it was hard to find (for me anyways).
I have Fox 2.5 suspension installed on my car with complete Timbren Active Off-Road Bumpstops, so later on i decided to go for Dirt King LCA since it gives 1 extra inch of travel and clearance for the vehicle, but i noticed it came with a 1/2" bump stop spacers for OEM bumpstops.
Sadly i don't know where i placed my OEM bumpstops and i couldn't find any information about OEM vs Timbren in terms of length, And by looking at the pictures for both bumpstops online it seems like the Timbren was longer and bigger.
But anyways it turned out that the OEM and Timbren is almost the same, the Timbren is less than 1/4" longer than OEM, and it wasn't touching the LCA, So i had to replace the bolt that came with Timbren bumpstops, i had to use a 40mm fully threaded M8 socket head screws.
Long story short, if you install LCA you with Timbren front bumpstops, you need 40mm long fully threaded m8 socket head screw.
Timbren-Bumpstops-Length
J150-Q8 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:50 PM #2
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
When I made a video about the Timbrens last year, I noticed the length is almost the same too, just more rubber to contact sooner.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 05:50 PM #3
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Originally Posted by J150-Q8 View Post
Hey Guys,
No concern that the bump stops wont function properly given their height and changes in travel?
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 06:28 PM #4
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
If you wanted definitive confirmation that the bumpstops would stop uptravel prior to the shock bottoming out, you can remove the springs then reinstall and cycle with a jack.
Or play it safe and install the spacer.
I'm confused as to why the spacer is required. Is the DK LCA at an angle or lowered at the bump pad? The increase in downtravel would be unrelated as that is most likely just due to the balljoint at the spindle and/or angle of the arm.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 09:34 PM #5
Crikeymike's Avatar
Crikeymike's Avatar
I'm pretty sure it's because the bump stop would sit lower due to the way the arms are fabricated. Without the spacer, the bumps most likely wouldn't engage properly
Old 01-09-2022, 03:06 AM #6
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Another option, Energy Suspension 8.9104R
Energy Suspension 8.9104R rear bump stops in place of front bump stops
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 04:58 PM #7
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by Akkording View Post
Gotta have pics mang!!!!! lol
to rest of ya'lls, thats what i use on my TC LCA's.. i didn't use the provided bumpstop spacer from TC since the ES bumpstops were already extended 1 inch. However, to those who are considering this route, you can still put the extensions if you want, but YMMV.
Also, be sure to get red...lol
Timbren Bumpstops + LCA + Spacer-thumbnail-16-jpeg
Old 01-09-2022, 10:06 PM #8
Akkording's Avatar
Akkording's Avatar
Ok here
40mm , bumpstops , lca , oem , timbren
Timbren Overload Bumps $100 SFO JZiggy For Sale: T4R Items 2 10-21-2019 11:04 AM
Airbags vs Timbren vs Rancho RS9000XLs? spetka 5th gen T4Rs 10 08-11-2017 11:33 AM
Timbren TORSEQ Rear Bumpstops Review jakehere 5th gen T4Rs 9 09-21-2014 05:31 PM
Timbren Bump Stops HB 4X4 For Sale: Suspension/Wheels/Tires 2 09-14-2011 01:19 AM
Timbren Suspension cj80cruiser 3rd gen T4Rs 4 10-12-2010 01:58 PM
