Old 04-10-2016, 04:33 AM #1
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Lifting Limited Quick Question
Just need confirmation that the full-time 4wd system on the Limited is OK if the vehicle is lifted 2-3". I know the part-time 4runners and Tacoma's can develop a front diff needle bearing issue, and that there's a bushing fix for it that works well. Any problems with the Limiteds other than likely scrapping XREAS? I'm looking to get back into a 5th gen. and wanted to double check before I sign any papers.. looking at a Limited this time around for various reasons. Thanks everyone.
JSparky is offline   Reply With QuoteReply With Quote
Old 04-10-2016, 08:44 AM #2
Dark Lord's Avatar
Dark Lord Dark Lord is offline
Real Name: Chris
Dark Lord is on a distinguished road
Dark Lord's Avatar
Real Name: Chris
Shouldn't be an issue. There are more than a handful of lifted Limited 5th Gens on here including mine.
Sent from my XT1254 using Tapatalk
2015 Limited 4x4 -- Icon Stage 2 -- Rokmen UCA -- SCS F-5 wheels in gunmetal gray -- Nitto Ridge Grappler 285/70R17
Instagram @roadwingit
Dark Lord's Cross Country Trip Report 2013
Dark Lord's Cross Country Trip Report 2016
Dark Lord is offline   Reply With QuoteReply With Quote
Old 04-10-2016, 09:57 AM #3
Bourbonator's Avatar
Bourbonator Bourbonator is offline
Bourbonator is on a distinguished road
Both Harper7 and Bimrunner have lifted and extensively modified Limited Editions..
'12 LE
'19 ORP
Bourbonator is offline   Reply With QuoteReply With Quote
Old 04-10-2016, 10:54 AM #4
cutty01 cutty01 is offline
cutty01 will become famous soon enough
Both Magnetic4R and I live in the Bay Area and have lifted our Limiteds. Magnetic4R is at ~2.5" and I am 2". There a bunch of others if you search the Lifted thread. I am happy to meet you if you want to check it out and go for a test drive.
When you remove the xreas follow the instructions in this PDF so you can reattach the shocks when you sell the truck or sell the xreas as a unit. Basically you disconnect the shocks at the self-sealing union fittings when all four wheels are off the ground. It is also less messy this way, where as other have disconnected the fittings at the shock itself loosing the fluid.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
cutty01 is offline   Reply With QuoteReply With Quote
Old 04-10-2016, 12:54 PM #5
rjfowler rjfowler is offline
rjfowler is on a distinguished road
I have a 2010 LE lifted with the Toytec spacer kit, no issues and still have XREAS.
2010 LE, lifted with 265/70R18
rjfowler is offline   Reply With QuoteReply With Quote
Old 04-10-2016, 05:35 PM #6
JSparky's Avatar
JSparky's Avatar
Those names are familiar, didn't know the were rocking Limited's. Thanks man.
Old 04-10-2016, 05:45 PM #7
JSparky's Avatar
JSparky's Avatar
Awesome, thanks for the offer and heads up on the xreas. I'll let you know what I end up doing here. There's a used 200-series out in Dublin I want to check out but I'll more than likely pick up a Limited t4r.. just gotta find one without the 3rd row which is becoming a little more difficult than I first thought. Should figure it out in the next few weeks so I'll keep you posted.
Old 11-12-2021, 05:58 AM #8
thebeardedsailor thebeardedsailor is offline
thebeardedsailor is on a distinguished road
So, I have lifted my LTD, probably a little above 3”; and now under hard acceleration the axle on the driver side skipping traction, also getting a clunk noise, if that makes sense.
I’m also getting a grind noise as if it’s “road noise” from the tires but when I turn on a hard curve to the left, the noise goes away. Anyone experienced this when adding a lift? I currently running the Ironman FCP STG 3, with a Daystar leveling kit.
thebeardedsailor is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 12:42 PM #9
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
With it being lifted so high, you need to install a diff drop kit if you have not already done so. The skipping of traction is prob due to topping out the suspension so the tire is starting to unload a bit. The grind noise going away on a turn may be that the outside tire is compressing which starts to put the CV's angle back to a safer position.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 01:50 PM #10
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Going over 3” is nuts. I’d take out the leveling kit because that pushing the suspension to the extremes.
Did you put in a diff drop and aftermarket UCAs?
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 06:00 PM #11
WNYJohn WNYJohn is offline
WNYJohn is on a distinguished road
Can’t wait to see where this goes, I’ve been wanting to lift my limited as soon as it isn’t my daily.
WNYJohn is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 06:01 PM #12
I’ve been waiting to lift my limited once it isn’t my daily, excited to see what you decide to go with.
Old 01-13-2022, 01:11 AM #13
Aftermarket UCA’s…diff drop coming soon, also I’m almost at 150k so I’m gonna swap new axles…bought it at 125k and this LTD has been from SC, Alaska, Germany, now Italy.
Old 01-13-2022, 01:12 AM #14
I’d say jump on it like white on rice! Up to 3” you ace! Plus parts are interchangeable with the FJ cruiser and GX platforms…FULLTIME4WD!
Old 01-13-2022, 01:14 AM #15
Ironman FoamCellPro Stage 3! Handles like a Porsche lol…very beefy suspension!
Lifting my Limited T4RAZ 5th gen T4Rs 37 04-04-2018 06:31 PM
Quick seat question. Limited vs Sport Hob 3rd gen T4Rs 23 09-19-2017 12:22 AM
Level Lifting my Limited with RAS southpaw2324 4th Gen T4Rs 2 10-24-2014 10:01 AM
Awaiting my Limited...bored...quick question regarding Eco Mode Ryan F. 5th gen T4Rs 12 07-22-2010 08:49 AM
