Old 01-04-2022, 10:09 PM #1
westwind77's Avatar
westwind77 westwind77 is offline
westwind77 will become famous soon enough
westwind77's Avatar
Spare tire carrier replacement - how hard?
I need to replace my spare tire carrier - how difficult of a job is that? I called the dealership and the quotes me about $525 for parts and labor, that also includes a new rim on the spare tire.
Parts around around $350 to $375, rest is labor.
I can source the parts out for a little less and I could get a cheaper rim somewhere and pay a bit less to have it swapped as well.
Just curious if anyone has done this themselves yet or not?
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
westwind77 is offline   Reply With QuoteReply With Quote
Old 01-04-2022, 10:35 PM #2
spartacus's Avatar
spartacus's Avatar
Have not replaced mine but the carrier is mounted to a cross member underneath with 4 bolts AFAIK.
Old 01-04-2022, 10:43 PM #3
westwind77's Avatar
westwind77's Avatar
That is what I saw from the looks of the diagram. Looks like you can drop the tire, remove the parts and re-install - not sure if there is an alignment trick or not that needs to be done though or if those bolts can be problematic to remove.
Old 01-04-2022, 10:56 PM #4
spartacus's Avatar
spartacus's Avatar
Not sure. Hopefully someone with the experience can jump in.
Old 01-05-2022, 11:09 AM #5
Humble Leader's Avatar
I actually had this done in the fall of 2021. I was at the dealer getting new tires/rims one of which was going to be my new spare. they were unable to drop the old tire because the original hoist was seized with rust (9 year old OEM part). the winch hoist is mounted to the cross member but it can be tricky to get to those bolts. As far as the install it seemed to be pretty quick once they actually got the old tire/hoist off
the bolts will likely be difficult to get to and if they are rusted will just add more headache unless you have a nice assortment of tools to help you out. hardest part is going to be the removal of the old assembly
Old 01-05-2022, 01:18 PM #6
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i replaced the one on my 4th gen. it's doable but quite difficult due to limited space. i had to cut my old one and use a thin socket to unscrew the bolt from the top.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 09:22 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Did it on my 4th gen couple of years ago, cable broke and switched it to the chain version. It was a real PITA and took me several hours with cutting wheel and whatnot as the nuts/bolts rusted solid.
labor , parts , rim , spare , tire
OEM spare tire carrier replacement- WTF onthejob 4th Gen T4Rs 30 05-09-2023 12:43 PM
WTB: 4th Gen Spare Tire Carrier and Carrier Guide jkemp Want to Buy/Trade 0 10-09-2015 02:17 PM
Spare tire carrier? 2nd gen. mack1 Classic T4Rs 7 09-24-2014 04:26 PM
Replacement Spare Tire Carrier Assy Nuke 4th Gen T4Rs 11 04-19-2013 04:41 PM
spare tire carrier pauls4runner 3rd gen T4Rs 10 10-21-2011 06:00 PM
