Old 01-09-2022, 09:23 PM #1
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
VSC, A-TRAC, DAC functions disabled, solution
Symptoms- VSC light on with check engine
light. No abs light.
-all ABS related functions disabled
-weird rpm fluctuations under no
throttle or braking.
-annoying 🦉
Solution-manually pulled codes via DLC.
Seven codes pulled (picture attached)
-focused on code which is an input for
all my other trouble codes (C1413)
Front right speed sensor malfunction.
-test harness and sensor for correct
resistance and voltage values.
-CLEAN SPEED SENSOR MAGNETO
TONE RING with q-tips and pipe
cleaner.
-blow out with compressed air
My whole truck works again 😂 skee pee!! Check this picture out. All these codes thrown from a dirty tone ring! Thought this might help some people out there that know their gas cap is on right 👍 seems to be a common issue on here with no good answers.
VSC, A-TRAC, DAC functions disabled, solution-img_20220109_191811592~2-jpg
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 12:50 PM #2
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
That's awesome, great troubleshooting! For future search reasons (maybe me one day!) I've transcribed some of your hand written notes below:
-C1443 Data not received for yaw sensor
-C1413 Front right speed sensor, check sensor, speed rotor, and harness
-C1427 ABS control unit shutdown...
-C1429 Brake pedal switch, monitored by skid ECU
-C1251 Open in ABS pump motor, no signal from skid control ECU
-C1963 Stability control inhibit steering angle sensor no input
-C1156 Wheel speed sensor communication, no steering angle input
And in this case C1413 seemed to be the main culprit fixed by cleaning the speed sensor magneto tone ring with Q-tips, pipe cleaner, and compressed air.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 01:10 PM #3
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Thanks sir! Hopefully it helps someone out one of these days ☺️
Old 01-10-2022, 01:17 PM #4
spartacus's Avatar
spartacus's Avatar
I went through the same process a few months back.
Old 01-10-2022, 01:43 PM #5
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Hey partner what was your situation? Is this bad luck, that photo looks familiar?!
codes , light , picture , sensor , vsc
An Alternative issue/solution to VSC TRAC VSC-off/ ABS light Billynath1988 4th Gen T4Rs 25 11-26-2018 10:16 AM
TRAC functions: on and off mywife's4runner 5th gen T4Rs 12 02-01-2012 05:25 PM
TRAC functions: on and off mywife's4runner Off-Roading 4 01-12-2011 12:10 PM
Is ABS disabled in 4Lo? Gerdo 3rd gen T4Rs 3 09-20-2010 10:48 PM
