Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 01-10-2022, 06:51 PM #1
mscot mscot is offline
Senior Member
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Senior Member
Quick Tire Advice Request
Currently we have Falken Wildpeak At3W 285/70 SL with about 6 or 7 32nds left.
They are really loud. Get caught in grooves of the road easily. And in general don't seem to track very well anymore.
Considering of skipping out on this last few thousand miles and getting Michelin Defender LTX as Costco has a really good deal on them right now.
Questions are: Will I see a substantial improvement in noise and handling (both tracking and the general feel - as I have mentioned before I think the truck drives really rough but it could be the eibach suspension)?
__________________
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 06:54 PM #2
spartacus's Avatar
spartacus spartacus is offline
Senior Member
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
Senior Member
spartacus's Avatar
They are absolutely the best tires, no noise do well in all kind of terrain, wet, snow as well as dirt good mpg. Their down side is that they look like street tires.
spartacus is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 07:00 PM #3
Senior Member
Senior Member
Quote:
Yeah. I know my truck is going to look even more like the mall crawler it has become but oh well. I'm a grown man and not concerned with others laughing at my vehicle.
Thanks for the advice.
__________________
Build thread
Old 01-10-2022, 07:03 PM #4
Gstick Gstick is offline
Member
Gstick will become famous soon enough
Member
How ironic this question came up. Over the weekend, I drove my friends 2021 SR5 4x4 1100 miles & he had the Michelin LTX Defenders on in the OEM size. I commented to him that his SR5 rode like a Cadilac. Extremely smooth & quiet compared to my Goodyear Duratracs. It was like a night/day difference.
__________________
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 07:14 PM #5
Senior Member
Senior Member
Cool. I'm going back to OEM size as well. Doing what I can to convert this to a road trip vehicle until we decide what to get next.
At least it's paid off.
__________________
Build thread
Old 01-11-2022, 01:08 AM #6
MannMade82 MannMade82 is offline
Member
Real Name: Jason
MannMade82 is on a distinguished road
Member
Real Name: Jason
General ATX
__________________
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 01:36 AM #7
Lexington's Avatar
Lexington Lexington is offline
Member
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Member
Lexington's Avatar
I have the BFG KO2. Great tires! I took them on a 3,000 road trip from the SF Bay Area to Colorado. Drive like a dream. Very good off road too. The only con is I saw my MPG drop a little. I use to get about 17.5 with the Terra Grapper and now I get about 17.
Lexington is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 07:44 PM #8
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
Quote:
What load tire are you running C, D or E?
What are pressure are you running too?
If you had suspension work done, did you have an alignment done at the same time?
Old 01-11-2022, 07:54 PM #9
Member
Member
I am running the Duratracs in 255/75/17 mounted on SR5 wheels with stock suspension. (winter/snow tires) They aren't listed as an LT tire in this size so I am assuming that they are a "Passenger" tire. Air pressure is at 38 lbs cold.
__________________
Old 01-11-2022, 08:10 PM #10
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
My $0.02? A SL load Duratrac is maybe not the right tire for the weight of these rigs. And running at 38psi isnt helping. Try dropping to 30-32 cold and see if the drive is better, tracking improves? You may lose a slight amount of MPG, but ride quality to me would be more important than losing 25 miles per tank.
For future, these rigs IMO run best in a C load tire. Move to a stiffer D or even stiffer E, and you really have to drop psi to make a comfortable drive, but then again, it all depends on what you do with your rig on the regular.
Old 01-11-2022, 01:51 AM #11
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Member
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Member
Jakeepoo3's Avatar
I have the same falkens and I love them. Not sure what noise you're hearing. I haven't noticed that. They also handle superbly and I'm an adrenaline junkie. This is my second set. My first set I was disappointed at first as they weren't handling well, with some body roll. The tire pressure is very important. I kept raising the pressure to stiffen the sidewalls until it handled like a coupe. On a 3" lift the magic number was 42 psi. I am on 2" wheel spacers also so that helps in cornering performance. I'm on an aftermarket off-road suspension lift also. You'll feel a lot more feedback from the road. You may need to switch to grandpa mode for the escalade or navigator 😬. The little skinnies may just have less noise but nothing else except for the lack of capability to use your amazing 4wd..
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 02:41 AM #12
Bry n Bry n is offline
Member
Bry n will become famous soon enough
Member
As you can see from my sig i wheel quite regularly but this rig happens to also commute 80 miles a day for work… I will tell you these toyos at3 are great on AND off the road… I’m at 42k miles and I still have enough tread to comfortably likely reach 55-60k before even needing to think of looking for new tires… when that time comes I’m getting 315s of the same tires
__________________
Follow my 4Runner on Instagram @chibi.4r
Bry n is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 06:42 PM #13
Senior Member
Senior Member
@Bry n Surprised you have gotten such good mileage on your Toyos. I'm already down to 6/32 and only have 25k on the Falkens.
Still, I'm not looking for aggressive AT tires. I'm not interested in typical ATs at all. The Cooper Discovers would be my limit and are still overkill. I just need enough for the occasional fire roads as most of the time the truck is used on road trips to the mountains or is our lumber getter. This truck is 90% road use now so I'm looking for something that handles better (not as jarring over bumps and holes) and is less noisy than typical ATs but still has enough grip to do some minor exploring. Everything I've read about the Defenders indicate that they are good for that but I wanted some advice from people with T4Rs that have had them. I read a write up from someone that does some pretty major overland type trips with either a Land Cruiser or LR5 (can't recall) with them and it was very positive - I just can't find the link.
I'm also interested in clawing back some torque the truck has lost with the larger, heavier AT tires and hoping the Michelins will do that.
But, hey, at least @Jakeepoo3 was able to come here and swing his dick a bit.
__________________
Build thread
Old 01-11-2022, 07:00 PM #14
Rack Rack is offline
Member
Rack has a spectacular aura about Rack has a spectacular aura about
Member
I put the defenders on my 4 Runner five years ago.
Two years ago I bought a set for My K2500 Suburban.
They work great on both.
__________________
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 07:38 PM #15
Mudballz's Avatar
Mudballz Mudballz is offline
Member
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Member
Mudballz's Avatar
LTX is a great tire only downside is looks I have a set on our rav4 3 years and have been perfect on my 4Runner I run wildpeaks with about 15k and they look the part as well as run like a gazelle through the woods
Mudballz is offline   Reply With QuoteReply With Quote
Reply
Tags
costco , deal , general , good , questions
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Advice request re: tire sidewall strength and offroading skag1T Engines / Suspension / Wheels / Tires / Audio / Accessories 8 06-21-2019 10:55 AM
Quick measurement request... Granth77 5th gen T4Rs 9 09-21-2015 05:31 PM
OEM jack and tire tools - Quick Photo Request! Fireball 3rd gen T4Rs 12 03-27-2013 08:14 PM
quick tire & lift advice Semperfly82 5th gen T4Rs 10 06-18-2012 04:15 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
