Old 01-11-2022, 10:01 AM #1
ASUMTNEER ASUMTNEER is offline
ASUMTNEER has a spectacular aura about ASUMTNEER has a spectacular aura about
Grinding noise
My wife's 2011 LTD 4X4 with 165k miles has been making a grinding noise, seems like in the front, for some time now. I checked the brakes and found a front caliper piston frozen, so I changed both calipers and the noise persists. The sound doesn't change when I use the brakes, so I don't think it's brake related. It sounds like a metal on metal grinding noise similar to a worn pad grating against a rotor, but the pads are 70% still. Could it be a wheel bearing? I can only hear it at low speeds, but that could be due to the road noise drowning it out at high speeds.
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 02:53 PM #2
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
There is a dust shield on the back that I once accidently bent when I was under there working. Pushed it against the rotor so when you drove it rubbed and caused a metal on metal sound. Got under and pulled it back out and problem solved. Hopefully this is your issue and an easy fix.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 03:36 PM #3
Thanks for the quick response, but I don't think this is it. I've pulled the wheels and sun the rotors in hopes of hearing something, but no luck. It's like it's only making noise under load.
Old 01-12-2022, 08:12 AM #4
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
Don’t recall if a 2011 LTD is on the front diff noise/ needle bearing problem, but could it be that.??????
BTW, Salisbury NC native Tar Heel here.👍
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 09:09 AM #5
Thanks for the response. I don't think this is the same thing. I had a 2010 trail that had this issue and it was a different noise altogether.
Old 01-12-2022, 09:30 AM #6
blanchard7684 blanchard7684 is offline
blanchard7684 is on a distinguished road
Take wheels off and rotate by hand each side. Compare. If it is wheel bearing that is really damaged you should feel a difference in smoothness.
If it is wheel bearing ensure diff oil levels are set appropriately.
Check for items rattling in the interior or rear hatch area.
grease u joints and drive shaft slip yoke to see if that makes any difference.
blanchard7684 is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 11:34 AM #7
greasing is a great idea! This is something I hadn't thought of. Thanks
Old 09-26-2024, 02:23 PM #8
mattyrides07's Avatar
mattyrides07 mattyrides07 is offline
mattyrides07 will become famous soon enough
@ASUMTNEER , what was the verdict?
2013 T4R TE w/ KDSS, ICON Ext Travel w/ ICON tubular UCA, Metal Tech upper and lower links, Sonoran Steel KDSS panhard bar, RCI aluminum skids, All Pro APEX sliders, 285/75/17 Yokohama Geolander MT, BMC, Front Runner rack, C4 front & rear bumper, C4 ladder
mattyrides07 is offline   Reply With QuoteReply With Quote
Old 09-26-2024, 02:28 PM #9
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough Captain Planet will become famous soon enough
I had a similar problem. It was in fact the dust shield. But when the brakes were cold, the metal contracted enough to not make contact. After driving a bit, noise was back. I went and bent it out a bit and noise never came back.
Captain Planet is offline   Reply With QuoteReply With Quote
brakes , front , grinding , metal , noise
Grinding noise Dads07sport4R 4th Gen T4Rs 10 12-31-2016 08:02 PM
grinding noise? flash23 4th Gen T4Rs 3 04-20-2015 09:44 AM
Grinding Noise gizmopt2002 Maintenance/Detailing 2 09-10-2006 03:23 PM
Grinding noise 06 ltd wlrunner Problems & Warranty Issues 3 08-10-2006 08:09 PM
Grinding noise when put in 4Lo N8G 4th Gen T4Rs 7 11-19-2005 07:32 PM
