01-11-2022, 04:32 PM
Ok, tell me like I'm an 8 year old. :)
I'm very mechanically inclined - with a full shop and many tools. That being said, I'm new to the 5th gen.
What should my dash "maintenence required" light mean at 12.5k miles?
I'm thinking at least an oil change. It pops on every 5k miles, right? That's about right for purchasing it at 8k and Carmax either servicing it or just resetting the message...lol.
Tire rotation - My tires are brand new BFG's with less than 2k miles on them.
Air filter(s) - my filters are brand new (I checked them when we bought it).
Do you do anything else regularly?
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
01-11-2022, 05:35 PM
Yep, that’s your oil change light.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
01-11-2022, 05:51 PM
Once upon a time, there were documents that came with vehicles that were called owners' manuals that had all sorts of information in them. In recent years, car manufacturers have included quick reference guides and electronic, searchable versions of these fabled manuals. It's believed, though it seems to be a fable, that owners were intelligent enough to look through these documents for themselves, but a rash of laziness and instant gratification has swept across the world. The result is multiple threads on forums, message boards, and Facebook groups asking the same questions over and over again.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
01-11-2022, 06:15 PM
Lol, lots of effort to call someone lazy and then not answer any questions.
And either way, while new thread count might go down a bit, there'd still be pages and pages of posts on those threads bc ppl come on here to ask, comment and share regardless.
But I'm sure that felt great to type out and hit Submit.
Also, Owner's Manuals were/are not Maintenance Schedules, those were separate included documents. They included what to change and check at each mileage interval, which is what the OP is looking for.
For example: Attention Required! | Cloudflare.
Maintenance Index | 4Runner 4Ever
01-11-2022, 06:23 PM
Yeah, I detest those guys........
so back to what I was asking, specific to 5th gen 4runner and their very non-specific "maintenance" alert.
oil, brakes, air filters, tires, wiper blades and of all things floor mats is what the maintenance schedule says, and then it lists like 15 optional tasks.
I listed my top three of oil, filters, tires and was asking, "What else do YOU (my charming, always fresh-smelling cadre of 4runner owners) check for regularly?"
01-11-2022, 06:26 PM
I listed my top three of oil, filters, tires and was asking, "What else do YOU check for regularly?"
Bolts on sliders and skids. One or two of them decide to disappear every year.
01-11-2022, 06:52 PM
Oh my gosh, I lost two off my skids and 3 off my sliders in Moab, before I started doing daily rig "wellness checks" . Had NO idea it would be such a prevalent thing!
01-11-2022, 06:55 PM
Real Name: BobH
Real Name: BobH
From my old 2013, but our T4s are going into year 12 with only minor changes.
01-11-2022, 06:57 PM
The "maintenance minder" reminds me that Toyota was too lazy to update there ancient software for the new synthetic oil changes at 10k. Now after 5k I am reminded that if i had only used regular oil I wouldn't have to stair at the maintenance minder for 5k.
I generally do oil changes every ~8k, rotate tires every 10k and the rest as needed.
Yeah, what's up with that? Somehow I lost a skid plate bolt too. lol
01-11-2022, 07:22 PM
i'll grease the uppers and lube the kdss sway bar bushings and anything with a zerk every 10k miles on top of the oil change. every 5k i just reset the light.
01-11-2022, 09:03 PM
2019 MGM TRD ORP
shootn4runner on IG
01-11-2022, 09:31 PM
Unfortunately maintenance schedules aren’t all that simple anymore. They add too many variation which just makes it worse. Most people just want a simple schedule. I found this dealer made a very nice Maintenance Schedule.
[url=https://www.toyotaofsantabarbara.com/4runner-recommended-maintenance-oil-change/url]
01-11-2022, 11:35 PM
Page 34 on does a good job at this, but you need to account for your actual usage. There is no "every 10k miles in all cases."
Also, page 34 gives you a list to look at every day you do anything "off road."
Best I've found. I'm going to turn it into a spreadsheet at some point.
01-12-2022, 08:17 AM
These are the regular maintenance things that I do/check:
rotate tires every 5k
change oil/filter every 10k
grease driveshaft every 15k
change diff/transfer case fluids every 30k
check air filter every 15k unless I offroad through a ton of dust(then immediately after such a trip)
check tire psi if temps change drastically
everything else is on an as needed basis. ie brakes, cabin air filter etc.
01-12-2022, 01:24 PM
12.5k maintenance lights just mean donate to your local dealer if you feel like giving
remove air filter and use a leaf blower to dust it out
invest in a tire tread guage and rotate tires when rears begin to show more wear than fronts (unless tire dealer requires rotations at certain intervals for warranty.)
