Old 01-12-2022, 02:27 PM #1
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
? for those with 5100 Bilsteins (clunking?)
For those that have the 5100 Bilsteins, do you get any clunking or other noises? I'm considering a set for my wife's 2020 ORP. The reason I ask is because I had Bilstein yellows on my 2012 WRX and they were loud and clunky across lightly rutted and washboard pavement. Big bumps were fine. I then got Bilstein yellows for my M235. The rears have been fine, but the fronts started clunking within 50 miles; same issue across lightly rutted and washboard pavement. I pulled them off and reinstalled 2 times to make sure I got everything correct. Turns out it's a common issue with Bilstein yellows. I was able to return them to the vendor for a full refund. I've found that Bilsteins are epically good when driven hard, but to have them be so loud and clucky during normal driving has been disappointing. I know the Bilsteins on the 4runner aren't yellows, but I want to make sure the same issue isn't common on these trucks as well. Thanks.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 02:58 PM #2
trdgmn's Avatar
trdgmn trdgmn is offline
trdgmn is on a distinguished road
trdgmn's Avatar
I've had the 5100s on for about a month and love them. No noises whatsoever.
trdgmn is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 05:32 PM #3
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I believe the yellow 4600's are valved softer than 5100's and pretty much the bottom level bilsteins. I have 5100s and they have been great for what they are and best bang for the buck.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 09:36 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Only for people who install the coil over mount upside down
Old 01-12-2022, 09:46 PM #5
RockyMtnT4R RockyMtnT4R is offline
RockyMtnT4R is on a distinguished road
Installed 5100s on all four corners a couple thousand miles ago and haven't noticed any noise from them.
RockyMtnT4R is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 11:04 PM #6
GearJunkie88's Avatar
GearJunkie88 GearJunkie88 is offline
GearJunkie88 will become famous soon enough GearJunkie88 will become famous soon enough
I had 5100s on all 4 corners for 3 years and they starting making clunking noises after about 9 months. I will never buy Bilsteins shocks again.
2022 SR5 Premium 4WD
GearJunkie88 is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 01:47 PM #7
mlaginess mlaginess is offline
mlaginess is on a distinguished road
I just put in a set, I have some clunking, but I'm pretty sure its sway bar endlinks. Or the sway bar bushings. I'll get it up in the air this weekend to sort out.
mlaginess is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 02:02 PM #8
Damn. I'm going to pass on these. The responses are very similar to those on the BMW forums with about 25-30% reporting clunking after a period time. I too thought the end links were the clucking culprit on my WRX and BMW. I disconnected them and drove around; still clunked. Other BMW owners did the same and had the same result.
There appears to be an inherent issue with the valving of the shock piston in certain gas charged Bilsteins. My guess is the shocks are so firm that it causes them to be too slow to respond over small bumps thus they tax the upper mounts and other surrounding bushings, thus creating noise over time.
Old 01-13-2022, 02:33 PM #9
clutchmoney clutchmoney is offline
clutchmoney is on a distinguished road
I've had them on for the past 3k - no clunking. They are definitely stiffer than the stock shocks though (50k on original suspension when removed).
clutchmoney is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 11:14 PM #10
Wbflyer Wbflyer is offline
Wbflyer is on a distinguished road
I had them on my 2020 with over 15k miles. They were perfect, on road.. off road. Just put on a new set on my new 2022. These are perfect so far.
Wbflyer is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 02:18 PM #11
Polyguy79's Avatar
Polyguy79 Polyguy79 is offline
Polyguy79 is on a distinguished road
Polyguy79's Avatar
Just put on 4 5100s last week. Stiffer than stock at this point in their life cycle, but no noise at all!
Polyguy79 is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 03:01 AM #12
Sgb020 Sgb020 is offline
Sgb020 is on a distinguished road
Just had a set installed on mine with the front set at 1.75. The rear I added the 1in bilstein springs. No clunking what so ever. I was nervous that I was going to make the ride worse. But I’m fact it rides more sporty, I liked how they turned out.
Sgb020 is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 11:51 AM #13
saltlife66's Avatar
saltlife66 saltlife66 is offline
Real Name: Dave
saltlife66 is on a distinguished road
saltlife66's Avatar
Real Name: Dave
have same on my 2018 ,, no clunking at all , just a better ride.
Bilstein 5100 1.75 front
cornfed 1" rear spacer
cali raised ditch lights
Falken wildpeaks.
saltlife66 is offline   Reply With QuoteReply With Quote
Old 01-14-2023, 10:26 PM #14
Cisco Kid's Avatar
Cisco Kid Cisco Kid is offline
Real Name: Jeff
Cisco Kid will become famous soon enough
Cisco Kid's Avatar
Real Name: Jeff
This will be a resurrection of an old thread here. About 45k miles ago I installed a full set of 5100’s on my ‘13 Trail. The front is set at 1.75” (3rd notch) with the factory springs and I have Cornfed 1” spacers in the rear. Over the last few months I have noticed a decent clunk coming from the front and rear. It was very apparent when a buddy and I were on some rutted up dirt roads just north of town as it sounded like something was very loose in the suspension. At this point I have been all over this thing and cannot find any loose fasteners. The front lower control arms are new (had the noise prior to this) and the upper ball joints have been replaced. All the bushings for the KDSS front bar have been replaced as well. There is no noticeable movement in the tie rods or ball joints when the front tires are off the ground. All the shock bushings look to be in good condition as well. Is it possible this is an internal issue with the shocks? What say you?
2015 Limited, bone stock for now
Cisco Kid is offline   Reply With QuoteReply With Quote
Old 01-15-2023, 01:07 AM #15
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Well this thread doesn't sound too encouraging.
I just had a set of 4 5100's delivered yesterday.
From reading here, it just happens on washboard roads?
Has anyone ever contacted Bilstein?
I suppose that would be appropriate.
seatia is offline   Reply With QuoteReply With Quote
bilstein , bilsteins , issue , loud , yellows
Tundra Bilsteins 5100 or 3rd gen specific Bilsteins 5100 cnpellegrino 3rd gen T4Rs 1 09-13-2019 12:00 PM
OME + Bilsteins 5100 NOOB4RUNNER 5th gen T4Rs 4 01-30-2018 12:54 AM
Will 285's fit on my Rig - Bilsteins 5100's 2.5/1.5 sullano4Runner 5th gen T4Rs 2 11-18-2016 01:09 PM
Adjustable Bilsteins 5100 - Which one??? CharliePR74 3rd gen T4Rs 17 11-18-2013 10:37 AM
TRD Bilsteins vrs 5100 450exc115 4th Gen T4Rs 1 09-14-2011 03:32 PM
