ABS, Tire Pressure, Brake, Traction, and 4LO lights on.
no CEL codes.
AC and Power Windows not working
Cant shift out of Park ( unless i use override).
I checked the ECU fuses but look okay.
I did drive it and i have powersteering and braking feels fine.
everything i've read on the forums lead to fuse and/or wheel sensor.
I dont think any rodents got to my wires.
Anyone face a similar problem?
****** what i did*****
I think I solved it after reading everything and anything on this forum.
the only accessory switch plugged into the kick panel fuse box are my switchpro, anytime backup camera + kdss on/off switch.
I ruled out the switchpro since i've had it installed for a few years now.
I uninstalled the kdss on/off switch.
I re-checked all my connecting wires to my anytime backup camera wires behind the headunit.
swapped out 2 10amp fuses for ECU-IGN no1 + no2.
No more dash lights and i can shift out of park.
I went back to run an errand and christmas lights all over again. smdh
ECU-IGN No1 + no2 fuse blown again.
I uninstalled the anytime backup camera (im going to miss my front camera
replaced ECU-IGN fuses and everything is back to normal. ran my errands and no christmas lights.
***QUESTION***
Maybe i was drunk when I installed this but - the tap fuse for the anytime backup camera, I had a 10amp and a 5amp in there. not sure why.
(i've had this camera installed and used frequently for well over a couple years now. no problem)
Does anyone think that when I flipped on the front camera/back camera it drew to much power to the switch but because i had 15amp fuse it blew out the ECU-IGN amps instead?
Or can anyone direct me to a website where I can read about how currents flow thru the kick panel fusebox?
