Old 01-16-2022, 06:13 PM #1
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
How screwed am I? Wrong oil filter.
I can't believe this happened, but I have driven over 17K miles on the wrong cartridge filters that were too short, allowing unfiltered oil to pass through.
I bought a 3-pack of OEM Toyota oil filters off Amazon and unfortunately I bought the 04152-YZZA1 instead of the 04152-YZZA5.
I am pretty pissed as I searched for the A5 but somehow the A1 popped up in the results and I added it to the cart without noticing that it was incorrect.
Usually Amazon warns you if the part doesn't fit the cars in your garage. That didn't happen.
So that was September of 2020. I just recently changed the oil for the third time using up the third filter. I recall being able to see the end of the perf tube poking out past the filter thinking it was odd, but not odd enough to cause alarm. I figured there was something inside the filter housing that sealed that up. I go online to check in case I screwed up. Sure did.
In retrospect, I feel like a complete idiot and cringe to think of all the unfiltered oil that passed through my engine.
So the question is, how effed am I?
Of course I stretched the hell out of the last oil change going damn near 10K miles. Normally synthetic would be no sweat but that, ahem, assumes a working oil filter.
At least I noticed right after this oil change, so I only went 300 miles or so on the third filter. Still, two full oil changes good for 17K+ miles on a short filter. ugh.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 06:24 PM #2
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
Dude, you are so F'd!
Kidding.
It wont make a difference at all. Would it have been ideal to have the right length? Yes. But in all reality, you only really missed about 10% of its filterability. To be sure, next time you change your oil, use a magnet in the extruded oil and see if you have anything in there. Chances are, you won't.
Old 01-16-2022, 07:41 PM #3
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Talking
Kidding.
I don't think he is truly screwed (l know you were kidding)
BUT.....being that his filter was short, the oil mostly likely flowed the path of least resistance and was not filtered (at least not much).
The air coming into the engine is responsible for much more wear than people realize. So as long as that and anything that cant allow sucking of air into the chamber or crankcase, you probably should not worry. Nothing you can do now.
I would definitely feel the oil plug for debris like Strongman suggests. And if you are going to worry about this, go ahead and send a sample off to analyzing, its cheap peace of mind. It will let you all metal levels and whether or not its in normal range.
Lastly...change your oil more often.
Its cheap and easy.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 08:41 PM #4
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
This is really common on Ford 6.0 diesels. They actually have two different filter lengths that match up to the cartridge. But there's no year specific or production model specific identity. It's just whatever somebody used the last time or you buy a new cap to match whatever you're putting on. It causes some issues in those engines. But they're also just really s***** engines that will turn I think 17 quarts of oil per oil change or something like that black as molasses in 3,000 mi. On your engine, it's a Toyota. Put the right one in and run it. I doubt you'll ever notice anything.
Good luck.
I think these sorts of issues might be part of why Toyota switched back to canister filters again. Too many ways to make mistakes on them that are hard to catch.
Jetboy is online now   Reply With QuoteReply With Quote
Old 01-16-2022, 09:16 PM #5
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
No issues, the oil was still filtered during that time. You just didn't have as much filter material available to fill up with particulates. A normal oil change interval still has life left on the filter under average circumstances. This is an intentional fail safe so that filtering is always adequate. You have absolutely nothing to worry about it.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 10:37 PM #6
SkidPalace's Avatar
SkidPalace's Avatar
Thanks. That’s what I was hoping to hear.
Old 01-16-2022, 11:36 PM #7
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
If you're that concerned about it, run a filter for a short time and then change element, top off and move on. Maybe. Run this filter for half your normal oil change interval.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 12:18 AM #8
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Also if you want you can go to your local auto store and buy a bottle of engine flush. You add it just before you do a oil change. Pour it in your engine and let it idle for about 5 min and then do your oil change. It’s suppose to help remove sludge and other harmful deposits.
Lexington is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 12:22 AM #9
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I performed a Google search and found a forum post where a Toyota dealer made the same mistake in 2015.
See Wrong size filter very upset | Toyota FJ Cruiser Forum It appears the OP, KinGriz is still active on the FJC forum. Consider contacting him to ask if any issue arose over the last 6.5 years. His post history doesn't show a follow up post, so it's likely any damage was not detectable.
DougR is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 05:14 AM #10
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Damn it I came back to this thread to see if his engine was going to blow up. Well this thread got real boring. Glad to see you have nothing to worry about.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 02:48 PM #11
lewdog998's Avatar
lewdog998's Avatar
Im not so sure about that. Lets say for example the Correct filter is 4 inches tall and the one he put in is 3 inches tall....well the shorter filter will not fill that gap between either the engine or the housing....so you would have oil flowing around the filter. The filter has to be sealed against surfaces on both the top and bottom to have ALL of the oil flow through the filter.
I get what your are saying about total filtration capacity, but i dont think that applies in this case.
If he has truly gone 17k miles with it in this condition, I would get a test done for peace of mind...and its only 35$.
go to amsoil and they have a kit for 34$$
How screwed am I? Wrong oil filter.-oil-jpg
Old 01-17-2022, 02:50 PM #12
lewdog998's Avatar
lewdog998's Avatar
I am sowing seeds of doubt now.......see my previous thread.
Old 01-17-2022, 04:07 PM #13
Correct, there is a face seal on the filter to the housing base so there would be some bypass of the filter. Strangely some manufacturers use an O-ring (see TRD or Royal Purple) and others don't seem to have much more than rubberized adhesive square ring like the Toyota filters shown on OPs post. There is a machined face in the filter housing base for the seal to contact.
However, a majority of the flow will still flow through the filter. There is so much FOS (factor of safety) built into the oil filtration system, it doesn't live on the ragged edge. Assuming OP has fairly normal driving conditions, doesn't live in dust storms and has a functional engine air filter i wouldn't be concerned if it was me. Most of us could greatly extend our oil and oil filter change intervals and never see the increased wear. Think... an engine that needs overhauled at 300k miles vs at 275k miles or 250k miles.
The post shows he was on his third incorrect filter at ~17k, when he realized he had been using the wrong part. With the first filter going 7k and the second 10k.
Spend the $35 if you want, but i don't know what you would do with the information. Say the results show huge amounts of wear metals and bearings are shot. What would you do with the information? Replace all of the bearings?
Old 01-17-2022, 04:40 PM #14
Ripper238's Avatar
Ripper238's Avatar
Not so worried about the wrong filter, but 17k between oil changes and the wrong filter.
Please tell us you were using synthetic.
Old 01-17-2022, 05:42 PM #15
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
I have a colleague that never changed the oil or filter over a 5 year period of ownership........he would just top off the oil when it was down a quart. Get this he sold the 4runner last week. It had 94,000 miles on it.
I could not make this up.
I am sure the next owner will change the oil and filter
I do mine every 5k, so you can imagine the conversations we have had.
Mark4runnar is offline   Reply With QuoteReply With Quote
amazon , filter , miles , odd , oil
Thinking the dealer used the wrong filter for my 10k oil change (none) 5th gen T4Rs 34 08-28-2023 04:20 PM
Wrong oil filter = big mess sam.basye 3rd gen T4Rs 7 08-21-2019 09:01 AM
Screwed up while changing my cabin air filter Andru1d 4th Gen T4Rs 10 04-15-2014 02:36 PM
We are screwed... JeremyH Off Topic 84 03-27-2010 10:55 AM
Used Wrong Oil Filter...I should be okay, right? Mister Skizzels 4th Gen T4Rs 3 10-05-2009 02:51 PM
