Old 01-17-2022, 02:53 PM #1
dcjeeper dcjeeper is offline
dcjeeper is on a distinguished road
Transmission fluid change tutorial and part numbers
I'm planning to change the transmission fluid of my 16 SR5 4WD myself soon. I want to replace the filter if possible, which means I need to take off the transmission fluid pan. Don't need a complete flush. Anyone knows if there's a detailed write-up with step-by-step instruction and all part numbers needed? There are some videos but no detailed part numbers included.
A related question is which diagnostic tool/OBD reader is recommended to read the trans temperature. I saw it somewhere but can't find it now. I also have a 17 Tacoma and hope the scan tool can be used for both trucks. I do have a temperature gun. Will it work if I just point at the pan to get correct trans temp needed?
dcjeeper is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 04:03 PM #2
DougR's Avatar
DougR DougR is offline
DougR is a jewel in the rough DougR is a jewel in the rough DougR is a jewel in the rough
DougR's Avatar
Go here: DIY maintenance quick reference - Toyota 4Runner Forum - Largest 4Runner Forum
Scroll down to "Replace Automatic Transmission Fluid" Part numbers are listed and there are 5 links to further discussions that will likely answer all your questions.
I don't replace the "filter". It's a large surface area screen for catching chunks. The super fine stuff in suspension passes through it.
DougR is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 04:30 PM #3
02SE 02SE is offline
02SE is a name known to all 02SE is a name known to all 02SE is a name known to all 02SE is a name known to all 02SE is a name known to all 02SE is a name known to all
Here's a good one by a member and former master tech: Comprehensive Guide to 5th Gen 4Runner Trans Service
02SE is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 05:30 PM #4
Thank you for the info. I've watched the video and read the quick ref too. Got most of the P/Ns but need the last one for washer of the 10mm pan bolts. I searched but couldn't find the exact item online.
fluid , numbers , part , temperature , transmission
A340F Transmission Solenoid Part Numbers? BamaDrewski 3rd gen T4Rs 1 11-07-2019 01:13 AM
Transmission Fluid change $$$ ToolmanJohn Maintenance/Detailing 5 07-03-2012 05:02 PM
transmission fluid change? meooem1 4th Gen T4Rs 8 01-11-2009 01:20 PM
fluid change...need part numbers 4Runner1371 Maintenance/Detailing 6 08-16-2007 12:18 PM
Transmission fluid change. T133 4th Gen T4Rs 8 10-04-2006 02:25 PM
