01-18-2022, 02:57 AM
Ironman UCA paired with Bilstein 6112?
Anyone else running this setup or even know if these are compatible? If so, what’s you’re overall thoughts on them?
I’ve found some pics of the Eibach kit with the Ironman UCA, but not with the Bilsteins. Thanks in advance!
01-18-2022, 06:12 AM
Here you go. 2.5” of lift with 4.7 degrees of caster. I have no issues with this setup. It drives and handles great.
01-18-2022, 12:15 PM
I ran the ironman UCA's for a bit and loved them. They make zero noise and i got about 3* of caster out of them.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
01-18-2022, 07:32 PM
3* total caster? or 3* additional?
01-18-2022, 07:56 PM
they should work fine, the bilsteins arent extended travel.
01-19-2022, 04:27 AM
Thanks! Must of missed your pic from other threads. I am at 2.5" lift on clips 7 and 5 with the Bilstein 6112s.
How many miles do you have on that setup?
01-19-2022, 04:29 AM
I follow you on IG, I think you said they rubbed....hoping that doesn't happen to me...
01-19-2022, 05:48 AM
I have 40k on the 6112’s and 25k with the Ironman UCA. No issues, easy to align, no noises. I am running 285 KO2’s with no BMC. I have no rubbing with this setup and I’m at 4.7 caster.
01-19-2022, 09:33 AM
What shocks do you have in the rear and what rear springs?
01-19-2022, 09:50 AM
i think he had them paired with a longer coilover. 6112's are meant as OEM replacement with no needed uppers. although i noticed a ton of improvement when i added uppers with the 6112''s for that castor.
01-19-2022, 10:06 AM
Not sure who this question is for but I’m running stock springs w/ a 1” spacer. I also have 5100 shocks. That will soon get changed out to the Dobinson 599 springs.
01-19-2022, 10:29 AM
Yes. It was meant for you. I’m also getting 5100 in the rear with the ome 2895e springs.
01-20-2022, 03:30 PM
I think it has more to do with the actual suspension I have; my Camburgs rub in the exact same spot.
We will see what happens when I install my Kings in the coming weeks.
My Camburgs make a bunch of noise that my ironmans did not make
