Originally Posted by Jetboy
How are you measuring the parasitic load?
Unhooked negative battery cable from battery. Put multimeter, set to "DC amps" and zeroed out, between battery cable end and battery terminal. Started pulling fuses.
There are a lot of wiki pages describing how to do this. One I just now found,
Measuring Parasitic Draw, give a LOT more detail than others, including waiting an hour. It also includes this gem:
"The most difficult part of making a parasitic draw measurement is establishing a “shunt” connection through your DVOM prior to disconnecting the terminal cable from the negative battery post."
I did not wait an hour, or maintain connection. I think that only matters when trying to find small loads (say 100 mA). Given my large load, even after pulling all fuses, I don't see how waiting for everything to sleep would help.
