01-23-2022, 10:02 AM
#16
use it for groceries
01-23-2022, 10:41 AM
#17
factory roof rack part of the solution
I carry two 17' canoes and the limitation of the factory rack is the narrow distance between the front and rear crossmembers. I need wider spacing.
On my Tundra, I use a 72" Yakima crossbar secured to the camper shell for the rear bar, using 2 control towers and Landing pad 6/7 secured to the camper shell permanently.
On the front, I use another 72" Yakima crossbar secured over the cab with Yakima Q towers and Q Clips specific to the vehicle.
On the 4Runner which I just bought yesterday, I will use Yakima Lowrider towers to attach the 72" crossbar to the factory side rails for the rear crossmember.
Over the front doors, I will use the Q towers and Q clips and a 72" bar. I bought the Q clips a few years ago anticipating I would get a 4runner. I'm not sure what number they are, they are not specific to the 4Runner but the word was the Q clips for Tacomas would work so I bought those.
Not great pics, but the Tundra is shown with even bigger canoes and the front bar over the cab. The Subaru shows the Lowriders hooking to the factory side rails. So on my 4Runner I will use those same parts, mix and match.
2012 4Runner SR5 4WD
2011 Tundra Doublecab 5.7L SR5 4WD
2013 Highlander AWD-Better Half
2005 Highlander AWD V6-Daughter
2006 Highlander FWD 4cyl-Son
01-23-2022, 10:53 AM
#18
Yakima lowriders on factory roof rack side rails
01-23-2022, 11:21 AM
#19
the rails themselves are fine, it's the OEM crossbars that most people replace because they have been known to bend and they have poor clearance above the roof
I have no issues with the OEM rails but I have 60" thule crossbars. I have my pelican boxes up there and keep some gear up there and out of the truck
01-23-2022, 01:07 PM
#20
I just bought a set of heavy-duty aftermarket cross bars so I could mount my box and Maxtrax to the OEM rails:
100% fine, solid and no problem at higher speeds.
01-23-2022, 01:50 PM
#21
Factory rood rails with Thule square bars and a fork mount bike rack. Works fine for what I need.
01-23-2022, 04:15 PM
#22
I have an early trail edition so the rack is different. But I have hauled kayaks on J bars on both the stock crossbars and my thule aero bars no problem. And I've hauled a ridiculous amount of lumber on it. Never had an issue.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
01-23-2022, 08:06 PM
#23
Originally Posted by Redsoxx1918
This is exactly what I wanted to see for transporting kayaks. Do you happen to have a link for the attachments for kayaks you are using?
01-23-2022, 10:26 PM
#24
To attach your LFD cross bars.
[Imgur]( https://i.imgur.com/n0yHsan.jpg)
I love them. I might replace the rails at some point, but these work just fine for my Runner.
01-23-2022, 10:36 PM
#25
They are Malone J racks. You can google them. They're a pretty popular, good quality J rack. They attach right to the factory cross bars. I keep them attached to the crossbars and just pop the crossbars off and store them in the garage until I need them. I like that the crossbars are so easy to remove and reattach or move around. It is high though. I have to throw a little step ladder in the back for loading and unloading.
01-23-2022, 10:48 PM
#26
Guest
Originally Posted by El Gavilan
The weight capacity of your roof will not increase because you added a Prinsu. Most of these racks add weight while using stock mounting locations, the non-drill ones leave the front part essentially unsupported.
But they do give you more space and look hype on Instagram. Try using the stock rack until you need something else. There is no need to throw 40-50lbs of extruded aluminum on your roof just yet.
Not true. Since most of these full length racks have "leg" or "feet" in the forward position, it has another point of contact and thus, an increase in static and dynamic load.
I travel with my wife (135lbs) daughter (165lbs) Great Dane Bull Mastiff (182lbs) American Bully (75lbs) and German Spitz (22lbs). Now add me at 310lbs and that's a lot of weight and room taken up by the interior. We carry our cooler and a reusable grocery bag with dog and human treats. I've run roofracks on my last two rigs and am in the process of sorting which roof rack I will want next.
I carry on a roof rack, when we go to our off grid cabin in NM...
Ax
Shovel
Chainsaw
Recovery Gear bag
My dry bag
Wifes Dry bag
Dgtrs dry bag
Kitchen gear
2.5G Rotopax fuel and water
Dogs gear bin
8' ROAM canopy
Grocery bin
Bin with camping essentials
For me, a roof rack is essential. I need the square footage of a full rack, not for the weight of an RTT.
01-23-2022, 10:54 PM
#27
To mount this big mo-fracky
01-24-2022, 11:26 AM
#28
Ax
Shovel
Chainsaw
Recovery Gear bag
My dry bag
Wifes Dry bag
Dgtrs dry bag
Kitchen gear
Dogs gear bin
8' ROAM canopy
Grocery bin
From the non-drill models, I've seen the forward legs kind of just hover. While loaded, they might "rest" on the vehicle they don't provide the same support as the rear bolted-in mounts. But all this is irrelevant since you are limited by the load capacity of the roof structure. Toyota's ratings are conservative, probably to avoid lawsuits, but I wouldn't assume 2-300 extra lbs won't make a difference.
Sounds like a full-length rack is something is working out for you.
01-24-2022, 11:55 AM
#29
The LFD cross bars are nice.
HEAVY construction. Stainless. Quality install hardware provided. Good price.
Subtle design too . . . doesn't look like you went shopping at BRovErLanDerS-R-US on the way home from the Toyota dealership.
Have had mine packed to the gills camping in the Mojave and doing some high-speed yahoo shit on the trails. Solid.
Jason
01-24-2022, 05:30 PM
#30
Real Name: Chris
Real Name: Chris
They TRD roof racks are ugly and junk, I think they made too many for the FJ's and just have been slapping them on TRD's because they had them. The stock roof racks are aluminum and can't hold much weight and the stock crossbars are useless
