01-23-2022, 01:04 AM
4th gen -> 5th gen advantages
I currently have a 4th gen V8 and had planned to keep it forever or at least until 500k miles. Now, my daughter wants to sell her '14 TE 4Runner and I am considering it.
What are the main advantages of the 5th gen Trail edition over a 4th gen Sport edition with a V8? I will miss the 4.7. Is there anything that will wake up the 6 cyl? I do like to camp/overland and have been planning to upgrade the 4th gen with lift, winch, rack, etc. for off-road adventuring here in Utah. Is the 5th gen a better platform for that?
Thanks!
01-23-2022, 01:52 AM
The '14 Trail has a locking rear diff, that the V8 4th gen never had. The 5th gen has more headroom. That was the main reason I never bought a 4th gen. There are forced induction options if you need more power.
01-23-2022, 03:22 PM
4th gen has a better turning circle. I have to 3 point turn to get into my small driveway now. And yes you will miss the V8.
01-23-2022, 04:14 PM
I have an 06 Tundra with the 4.7 and it eats gas, about 15 tops.
I suspect your 4th gen does too. I suppose the 5th gen with the 4L should do better.
Either one has one of the best engines Toyota ever built. If you don't have a hankering to get a newer vehicle, you won't go wrong keeping your 4th.
Joe
2012 4Runner SR5 4WD
2011 Tundra Doublecab 5.7L SR5 4WD
2013 Highlander AWD-Better Half
2005 Highlander AWD V6-Daughter
2006 Highlander FWD 4cyl-Son
01-23-2022, 10:23 PM
Joe
My 2004 V8 Limited with a small lift and bigger tires got 14 mpg. My 2020 ORP with stock everything gets 14 mpg.
01-23-2022, 11:58 PM
You must drive very aggressive.
My 2021 trd has averaged 20.3 for the last 13k. My 3rd gen 3.4L gets the same.
5th gen has less to worry about for age rot and maintenance, otherwise idk if there's a big difference.
01-24-2022, 12:09 AM
One disadvantage of the 5th gen is the V6. Living in the mountains, this thing struggles sometimes climbing steep passes.
01-24-2022, 01:15 AM
The e-locker would be nice to have. Obviously, I could go with an ARB setup on the 4th gen, but that is a chunk of money.
01-24-2022, 01:16 AM
Joe
Maybe I'm oblivious but my 4th gen isn't too bad. I'd say 18 on average. I do a lot of freeway though.
01-24-2022, 02:05 PM
Thanks!
One big disadvantage, in my opinion, is that the 5th gen is only part time 4WD. Put it in 4WD and you'll get binding from the transfer case. The 4th gen has a limited slip in the transfer case, you don't get the binding with that.
Current: 2017 TRD Off Road with KDSS
Previous: 2003 Sport Edition AWD
Before That: 1993 Pickup, SR5 V6 5MT Extended Cab 4WD
01-24-2022, 02:57 PM
Less than buying another car.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
01-24-2022, 03:15 PM
Very true.
01-25-2022, 04:48 AM
So why did Toyota change this? I think I would prefer the limited slip.
01-25-2022, 11:41 AM
Toyota hasn't said why. Speculation is cost savings.
01-25-2022, 11:43 AM
5th gen Limited is still full time 4WD/AWD with locking CDL, same as the 4th gen V8 4x4's. V6 4th gens were only part time 4WD as well, only the V8's were full time (and possibly limited trim, not sure on that).
I have a GX470 (basically a 4th gen V8), and had a 5th gen Limited at the same time. Adding a Sprint Booster/Pedal Commander made a HUGE difference on the 5th gen, totally transformed how the power is delivered. The 5th gen's V6 actually makes more power than the V8 in the '03-'04 non-vvti models, the difference is negligible once you've addressed the awful throttle by wire of the 5th gens, but the V6 does like to be revved to make its power compared to the V8. Even compared to the '05+ V8 with it's power bump, you won't be disappointed unless you're doing a lot of towing, where the V8's torque comes in handy.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
