Old 02-01-2022, 12:39 PM #1
Pirateghost Pirateghost is offline
Pirateghost is on a distinguished road
Filter Size Wrong
Used to change my own oil using only OEM oil and filters. Had to have dealer do it yesterday. Tech informed me I had wrong filter size. I have been meticulous about using correct parts. My box says 04152-YAAZ5. Specs say it should be 4.8 x 3.2 x 3.2 inches. My filter out of OEM box measures 2 3/4 x 2 3/4 x 3 High. How can my sealed box OEM filer be short by almost 1.8 inches?
Edit: Sitting here pondering this again and looked closer at filter. It is indeed stamped 15613-YZZA2 and not 04152-YZZA5 like the box says so at some point something happened. Box was just opened by me and was sealed. If changing oil, may want to examine filters closely before just whipping in a new element like I did.
2020 Limited
Pirateghost is offline   Reply With QuoteReply With Quote
Old 02-01-2022, 03:24 PM #2
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
Is this an OEM filter?
If it indeed has a different stamp on the filter than from the box (and does not include a statement about including/replacing additional filters numbers) I would do a few things:
1. Retain a sample of the old oil and confirm with oil analysis that the metal content is not out of spec.
1a. If it is out of spec, contact whomever you bought it from and send them pics of the filter and box.
1b. If it is really out of spec, contact an attorney since there was a mistake (intentional or not) that WILL affect the longevity of your vehicles motor.
2. Contact who you purchased it from and ask to speak to a regional manager.
3. If Toyota directly, then onto Toyota CS.
4. Consider only buying from your Toyota dealer directly from now on.
More than likely, its a non issue, but I would want to make sure with a $6,000 motor/labor bill that could come sooner than later.
Old 02-01-2022, 04:30 PM #3
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
15613 is the part number for the filter material. 04152 is the part number for the whole kit in the box including gaskets.
Thinking the dealer used the wrong filter for my 10k oil change
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
box , filter , inches , oem , size
How screwed am I? Wrong oil filter. SkidPalace 5th gen T4Rs 31 09-26-2023 08:56 PM
Thinking the dealer used the wrong filter for my 10k oil change (none) 5th gen T4Rs 34 08-28-2023 04:20 PM
Wrong oil filter = big mess sam.basye 3rd gen T4Rs 7 08-21-2019 09:01 AM
OEM wiper inserts are the wrong size Mabuse 4th Gen T4Rs 4 11-12-2009 07:33 PM
Used Wrong Oil Filter...I should be okay, right? Mister Skizzels 4th Gen T4Rs 3 10-05-2009 02:51 PM
