Old 01-26-2022, 02:21 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Blown Shock?
Lately, I’ve been noticing a weird feeling when turning. Almost feels like the rear end wants to slide out. Happens at low speeds (when turning from a stop) and high (like a curve in the highway) I did slide once, but that was with the rain. At first, I thought it was due to rain and oily surface, but now I feel like the handling feels off and not like it used to because it happens when it’s dry out as well. I looked underneath and checked the swaybar for looseness, but saw this on the driver side rear shock (see pics) it’s a Bilstein 5100 with the 2” heavy spring from Toytec. Only the driver side as the noticeable residue at the bottom of the shock and boot.
I’ve had this setup for maybe 2-3 years now. I see what appears to be grease coming from the bottom of the shaft after pulling the rubber boot down. I checked the passenger side and it seems dry. I tried jumping up and down and pushing the rear bumper up and down and can’t really notice if the driver side and passenger side feel the same. Other than feeling like the rear end wants to give out, I don’t notice any changes to the ride quality. Tires are in good condition so I ruled that out as well. I do have a drawer (single sided on the driver side; roughly 100 pounds.
Blown Shock?-cd8cb248-c9ae-40ef-b001-f6e55453ac5c-jpg
Chilow is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 02:25 PM #2
Here’s an additional pic of the boot
Blown Shock?-58092cb3-c2af-4411-bc5c-8a3d50a7d04f-jpg
Old 01-26-2022, 02:29 PM #3
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
Pull the shock off and push down on it to see if it still has any rebound. Bilsteins are so cheap, might as well just throw a new set on in the rears to give you the piece of mind.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 06:32 PM #4
Trying to avoid pulling the shock. If it is blown, I’d prefer to order replacements and do it all at once instead of pulling the shock to test it, put it back in and then remove and place. This is my daily driver.
Old 01-26-2022, 06:37 PM #5
2016 White TEP
Old 01-26-2022, 07:36 PM #6
spartacus's Avatar
spartacus's Avatar
It's one bolt at the bottom. Undo it and test it and push it back on to the perch. 10 MINUTES.
Old 01-27-2022, 08:51 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I would replace the rears if you noticed a change in drivability, maybe do the fronts as well. Rears are an easy job on the 4runner! It might not be blown, might just be misting some and trapped in the boot. Read up on misting shocks. Just make sure you don't tighten/torque the lower bolts while it's in the air. Read up on it.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 10:04 AM #8
if its leaking oil that means theres still oil in it ;) just order a new set, swap the one out, keep the other as a spare. or upgrade to fox 2.0's with a shaft guard.
Old 01-27-2022, 10:55 AM #9
Humble Leader's Avatar
that shock is blown. slight weepage is generally ok, but that is not weep. that is a leak. if that rubber boot wasnt there it would be all over the place
Old 01-27-2022, 11:24 AM #10
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
I agree. Blown, time to replace.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 10:30 PM #11
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I changed bilstein shocks on all my vehicles .. my 2000 silverado I changed the shock in 2004 .. the right front Bilstien shock had oil dripping now ... I will have to replace it in the spring ...
your shock had grease in it / on it ? I never had any shocks in grease .. just oil ...
catrains is offline   Reply With QuoteReply With Quote
driver , feel , rear , shock , side
Blown shock...again sparkyy192 5th gen T4Rs 11 04-27-2021 11:36 AM
OME blown shock? TXRick 3rd gen T4Rs 2 11-15-2015 02:10 PM
Blown Shock, Ya or Nay ? smallfry 3rd gen T4Rs 1 06-19-2013 11:15 PM
Blown shock? 4Runner93 3rd gen T4Rs 1 02-24-2011 01:00 PM
