01-27-2022, 01:31 PM
Are strut spacers bad?
I saw it mentioned here that someone said strut spacers are dangerous.
I have a new 22 TRD OR and am happy with it other than the aggressive rake. I think I'd be happy just putting .250" spacers on the front struts for a .5" lift and some KO2s in 265/70/17 to keep it as minimal as possible. Spacers are stupid cheap but I don't want to do it if there's safety issues or whatever. Kinda like wheel spacers I guess.
So are they good to go or no?
Thanks.
01-27-2022, 01:56 PM
You are good to go. I have the RoughCountry leveling kit which raises the front 2.5 to 3 inches and the rear 1 inch. They are spacers. I also run KO2 tires in stock size. I have run this set up on some really difficult trails (Alpine loop in western Colorado) and have had zero problems.
The truck rides just the same as original because no springs or shocks are changed. Much, much better than the Jeep Cherokee and Wrangler I had in the past.
My opinion is that you do not need wider tires. The KO2 have a slightly wider tread than the OEM tires, but the diameter is just the same. I got the load range E tires (more plys) due to the sharp rocks I encounter off roading.
Be sure to get a good wheel alignment after the spacers are installed.
01-27-2022, 02:14 PM
Why Spacer Lifts are Bad!!! - Chi Town 4x4
I personally think a set of bilstein 5100s is a better option for just a little bit more money, but that's just my opinion.
2016 White TEP
01-27-2022, 02:49 PM
Coil spacers add preload to the springs which make the ride stiffer. Top plate spacers move the whole coilover assembly down which can cause the shock to bottom out before the suspension hits the bump stock which can result in bending. Most small spacers are ok but I'd just put my money into 5100s. Temporary lifts until you can afford what you really want never made sense to me.
01-27-2022, 04:08 PM
They do make the ride more firm and can cause more wear and tear on the struts
I had 2.5" strut spacers for about 27k miles until I upgraded suspension. The strut spacer gave me the look I wanted and allowed me to fit 34's at the time. I beat on it and never had an issue, and the slightly firmer ride did not bother me one bit.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
01-27-2022, 04:10 PM
I ran a 2.5 inch spacer on my old 4th gen for many years with lots of off road with zero issues. I have run a 1/2 inch spacer (1 inch lift) on the front of my 5th gen for 5 years now again with zero issues. Both rode and drove like stock.
01-27-2022, 04:15 PM
I can do 5100s no problem. I just didn't know what was preferred between preloading the front 5100s to get a .5-1" lift or by just doing spacers.
01-27-2022, 04:59 PM
The 5100s have 3 settings. .85", 1.75", and 2.3" I believe. There are just 3 rings on the shock bodies where you set the lower coil mount. You'd have to move your coils over anyway to the new Bilsteins, so just tell the shop which one you want.
FWIW, I didn't want to spend the money on 5100s since my 4R only had 30k on it and I really don't wheel much. It was $50 for .5" front Cornfed spacers for 1" of lift and I think it looks great with stock sized KO2s. I probably wouldnt bother with .5". My 4R drives exactly as stock. Getting up into the higher lifts doesn't make sense to have spacers, but I don't see the reason to spend money on new struts if you are only leveling it a little bit.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
01-27-2022, 09:47 PM
Real Name: BobH
Real Name: BobH
Originally Posted by srsrogerissrs
I added 5100s with 0.85 setting. No more rake, almost level and the 5100 were only a little firmer, reduced the nose dive and felt a lot better for off road trips. The photo is with OEM tires, before the AT2s.
01-27-2022, 10:08 PM
If you're not going to beat on it too hard, run spacers. My 4R came with 3"/1.25" and I wheeled it decently without issue.
I'd recommend getting Durobumps as well to smooth out when you compress the suspension.
01-27-2022, 10:25 PM
Mall crawler approved, goes well with all the pristine broverland stickers.
01-28-2022, 01:42 AM
Love the user name haha
01-28-2022, 09:08 AM
Lol thanks. Kind of an inside joke.
Thanks for posting this. This is exactly what I want.
I’m sold on the 5100s and probably C rated KO2s.
01-28-2022, 10:28 AM
Real Name: Ron
Real Name: Ron
I guess i'm a little dense on this subject even with the Bilstien explanation.
I'm running a 1" Dayco spacer on top of the top hat with 4600 Bils and FJ springs and it did exactly what I had hoped, lifted the front to be level, or very close with the rear. I don't see how this moves the shock down if the front is raised up.
When the spacer is put on top of the spring between top hat and spring and compresses the spring how is that any different than what a 5100 does when you compress the spring by moving the clip/spring seat up?
Duhhh!
I would need to make my own measurements to convince myself as to what is happening here. Chi 4x4 explanation on shock travel, which may be accurate, does not make sense to me.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
