Originally Posted by TEujunga
You aren't dense. The people who persist in perpetuating the "preload myth" are. I thought the "preload myth" had died a deserving death years ago, but like a bad virus, it just keeps coming back.
There's no such thing as "preload" on the T4R coilover. With the weight of the vehicle resting on it, the spring will always be compressed the same amount no matter where you put any spacers or circlips or what have you. You're effectively moving the spring perch, not changing the spring rate.
Moving the clip on a 5100 accomplishes the same thing as adding a spacer. The difference is that the 5100 shocks are longer than stock, so the overall travel range is potentially increased. Adding longer springs is necessary to take full advantage of this.
Thanks for your response. I have been thinking about this and scratching out some drawings and I think I understand some of it better. I can see how the "strut extension" which is the method I used increases the overall length of the assembly. By doing this I can now see something has to change with travel, Since the upper end of strut is bolted to a fixed location, the strut tower, the length increase will push the LCA downward, also the LBJ, so travel will be negatively impacted as the LCA downward travel is reduced from what it would be with standard length shock/strut.
The 5100 shock length remains the same no matter what clip you put the perch on, so shock travel should remain the same, but compressing the spring makes it stiffer and when the vehicle weight is placed on it, the vehicle doesn't compress it as much as before and results in "lifting" the body a certain amount.
The preload kit on top of the spring and between the top hat will actually cause the shock to lengthen from what it was and I can see that this will affect it's travel from what it was without the spacer and this will affect the shocks available assembled travel.
I think my thinking is correct here and Chi Town 4x4 was saying this but not explaining why in enough detail for me to grasp it. I would like to see this scenario played out on a 4Runner suspension so I could see what's happening. This summer I will take some static measurements on mine with and without the spacer and see if I can wrap my mind around it some more.
Does what I'm saying here make sense?
