Old 01-29-2022, 12:17 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
URD Y-pipe won't fit. Warped headers?
I had a rear cat stolen a while ago so got a URD Y-pipe (which is very nicely made) instead but can't get the bastard lined up. I have the stock headers/upsteam cats and tried removing the studs, loosening the bracket bolts, etc but can only ever get 3 out of 4 holes lined up. URD says the stock headers can warp but they look ok to me I dunno. I'm about to email them back with the pics. I don't really want to send it back and I doubt they want a return because it was $100 to ship it and I imagine they test these things on a template before sending them out. It's made of 304 stainless and looks extremely difficult to bend. I don't really trust a muffler shop not to damage it forcing it on there (which I can do myself for free ).
I feel like I might be able to brute force it with a long pry bar but then it would be under a lot of tension. If I did that will the headers unwarp themself or the Y-pipe get hot enough and "settle" to remove any strain so to speak? The other thought I had was heating it with a torch to massage it in to position. I'll need to take this thing off again if I ever have to drop the AT pan so I'd like it to fit nice.
It needs to be kind of twisted on either side to fit, not bent exactly. Any thoughts?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 01-29-2022, 03:58 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
What you show is not enough to worry about IMO, so I would "massage" them into place, bolt them up and go.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 01-29-2022, 04:24 PM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I would give URD a call first before I brute forced them..They may advise heat to make them move into place with persuasion.
Best Regards,
Saker
Old 01-29-2022, 06:38 PM #4
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
It appears there is a slight warp on the end that doesn't line up. I'd unbolt whole thing and start with these 2 where the warp is (do not tighten). Then, give it slight steady pressure and rotation to get other 2 bolts that you know lined up fine before. Tighten all 4 up and you should be good to go. Don't be too shy about it. G.L.
<<<< is offline   Reply With QuoteReply With Quote
Old 01-29-2022, 08:57 PM #5
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Agree with both Saker & <<<< ! Call & show them your pics , mine didn't line up in rear very well & had to warm up to get it line up ,still have to tighten up from time to time !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 01:14 AM #6
i was worried about this when i installed mine, i got lucky, zero issues. that doesnt look too bad to "massage" into place though. I agree, dropping the tranny pan for service might suck if theres tension on the new y pipe.
x2, its a super nice piece of exhaust work.
fit , headers , stock , urd , y-pipe
DT Long Tube Headers and Y-Pipe CEL issues. Bpzimm 4th Gen T4Rs 24 12-14-2022 01:15 PM
WTB 4th Gen DT Long Tube Headers and Y pipe 16ranas Want to Buy/Trade 0 11-02-2021 01:27 AM
Headers/y-pipe/exhaust MikeMikeMikeT4R 5th gen T4Rs 17 01-23-2021 09:57 AM
Smog tests, headers and y-pipe?? 4runnerfourplay Engines / Suspension / Wheels / Tires / Audio / Accessories 6 02-24-2009 10:48 AM
