Old 02-05-2022, 01:51 PM #16
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by Jakeepoo3 View Post
That is the same thing I'm thinking. The head gasket/compression is fine and the whole inside of the truck got wet and fogs up from the busted coolant system. There are sensors mounted on the radiator support. I believe they are airbag or crash sensors?? I don't have af_ucking $400 repair manual to find what should be easy to access to the vehicle you own. No critters, I was trapped in the truck until I was found 😆 I'm dirty south old school! Walked five miles to the highest elevation just to get a 911 signal and be found whilst burning a fire to keep from freezing to death 👽
Here's how you can get the manual.
TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
It takes typing in a URL and un-zipping a file, but there you go.
rageandlove is offline   Reply With QuoteReply With Quote
Old 02-08-2022, 05:04 PM #17
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by nglayton View Post
Seems odd the inside would have an issue if it was just the radiator.
Yellow sensors/ yellow wire wrap are the airbag sensors.
Yeah i have an airbag code 64. Cel code 22 I believe faulty coolant temp sensor. My engine is fine. Hopefully it's just the coolant sensor preventing it from starting in freezing temps.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 02-08-2022, 05:05 PM #18
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Thanks land cruiser hooked me up with the repair manual already ��
Old 02-08-2022, 05:17 PM #19
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Finally thawed out been encapsulated in ice and snow for a week here. Pulled CEL code 22 faulty temp sensor. Airbag code 64. And I meant compression test 100% not psi 😂. I already pulled the radiator. I'm thinking this tin can radiator support is the whole reason I got f_cked. It needs a real steel tube support. Get what you pay for my assh0le
Old 02-10-2022, 06:10 PM #20
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Originally Posted by Land Cruiser View Post
PM sent
I forgot to give a shout out to Land Cruiser! So much smoother and enjoyable to have the proper information right when it's needed. Thanks for the hookup Arkansas 🦉🦊
cracked , drove , engine , radiator , start
Has anyone replaced their radiator core / tank(s)? eurasiaoverland 3rd gen T4Rs 1 05-04-2016 01:43 PM
1st gen radiator support Justin_W Classic T4Rs 1 08-11-2014 07:43 AM
radiator core support mounts Kenjan 3rd gen T4Rs 2 06-18-2012 06:00 PM
Core radiator value......... 77'911 Classic T4Rs 7 05-07-2012 11:55 PM
1995 4runner core support/radiator support bolted vs. welded into frame jlfindley74 Classic T4Rs 3 12-28-2010 05:59 PM
