Old 02-03-2022, 04:17 PM #1
jtack jtack is offline
jtack is on a distinguished road
CH4x4 Switch Help Please
I've installed some KC Flex ditch lights on my '19 4Runner. Instead of using their included rocker switch, I purchased a CH4x4 switch. I also purchased a wiring harness that included a relay. The harness also included a switch, that I cut off.
The relay has a red/black/yellow wires going to the switch. My CH4x4 switch has 2 red, 1 green, 1 black wire. Can someone give some direction to which color switch wires, go with with which color wire on the harness. I found some people wiring the (2) red switch wires together which will enable the switch to come on when the lights are activated. But I'm lost as to which wires to match up on the harness.
Any help would be greatly appreciated. Thank you!!
I've attached an image of what I have.
CH4x4 Switch Help Please-snip20220203_146-jpg
jtack is offline   Reply With QuoteReply With Quote
Old 02-03-2022, 07:33 PM #2
any harness can have any color wires. so you need to either find the harness diagram or get a test light and start figuring out what does what. You can hook it all up and start connecting wires to see what does what. you may or may not pop a fuse lol..or start a fire.
Old 02-03-2022, 07:59 PM #3
Thanks for the info! Unfortunately the harness does have a diagram but it doesn't specify what the different color wires are for the switch because the switch is part of the harness. I cut that switch off.
Old 02-03-2022, 09:20 PM #4
Makes sense...i did the "might start a fire" method
Old 02-03-2022, 09:21 PM #5
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
That looks to be a standard 5 pin relay. Look up what each pin is supposed to do and trace the wires from those pins. Easy stuff
NB17Limited is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 01:27 PM #6
Perfect - Thank You!!
ch4x4 , harness , included , switch , wires
Push switches - CH4X4 vs RAGO vs Air On Board vs Mictuning chillfancy 5th gen T4Rs 7 08-26-2022 05:13 PM
Not Happy With CH4x4 Switch, Should Have Gone with AOB cutty01 5th gen T4Rs 65 05-17-2022 01:39 PM
FS: CH4x4 Industries VSC Switch ON/OFF - $30 Alberta, CAN. crackystride For Sale: T4R Items 2 09-24-2019 08:54 AM
cH4x4 Switch <<<< 5th gen T4Rs 5 01-18-2018 02:44 AM
Electrical Switches from CH4x4 light color choice alia176 4th Gen T4Rs 2 02-21-2017 11:52 AM
