Old 02-07-2022, 09:07 AM #1
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
2020 4runner - Drive start control malfunction, braking power low, ABS and PCS issue
hello, i can't believe i'm getting this error on my dash. tested the truck and the braking seems to be working fine, however the ABS seems to be not functioning. i tried it in 2wd while the car is on ice, ABS don't work. placed it in 4wheel drive, it works fine but not in 4low. i've seen some threads and they ended up getting the abs system replaced. anyone had this and what fixed it?
1. drive start control malfunction
2. braking power low
3. ABS malfunction
4. precollision system malfunction
4r-4ever is offline   Reply With QuoteReply With Quote
Old 02-07-2022, 12:14 PM #2
spartacus's Avatar
spartacus's Avatar
3. ABS malfunction
Here is the thread. A few have had the issue.
ABS, braking power low and drive start control malfunction lights
Old 02-07-2022, 01:33 PM #3
thank you. that's what i saw.
Old 02-08-2022, 01:49 PM #4
i can't believe i fixed the ABS related issue on my 4runner. it seems like a software glitch on the system. when those error show up, the truck is drivabable except the abs system stopped working and the 4wheel drive system still works for 4h and 2h but not 4L.
while i was driving earlier, i tried pressing the brake with my left foot while i'm pressing the gas to accelerate and suddenly all the error disappeared. i tested the 4 wheel drive system, 4H, 2H, 4L, atrack, traction control and downhill assist started working again. i tested 1 wheel on ice while in 2H and the ABS worked also. if you have these errors, can you try these fix and let me know? there must be something that must have been done with the braking and gas pedal to activate those malfunction. now it's fixed. i wonder if toyota is aware of those issues.
Old 02-08-2022, 04:17 PM #5
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
How'd you get the idea for that?
Forgetful is offline   Reply With QuoteReply With Quote
Old 02-08-2022, 04:46 PM #6
i have the error, drive start control malfunction and i tried to read the manual and it says these.
When buzzer sounds: - i don't get the buzzer sound.
- brake override system is malfunctioning
- drive-start control is operating
- drive-start control is malfunctioning or
- follow the instructions displayed on the multi information display.
When a buzzer does not sound: - this is what i followed but pressed the brake and gas pedal at the same time.
- brake override system is operating
- release the accelerator pedal and depress the brake pedal.
Old 02-08-2022, 06:11 PM #7
That's super odd, I'll have to file it away in my memory if it happens
Old 02-09-2022, 12:54 PM #8
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Is everything still working? I forwarded this potential fix to my service advisor and he said he forwarded to the tech. We'll see.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 02-09-2022, 01:37 PM #9
yes, drove a few miles this morning to do some errands. everything is back to normal so far. i'll post more in here if it comes back.
Old 02-09-2022, 01:45 PM #10
by the way, my wife was driving it when it happened after that ice storm. told her to put it in 4while drive - 4H then it happened and called me.
i don't know why when she drives it and our other cars, all kinds of crazy stuff happens. I'm not going to let her drive my 2020 4runner again, lol!
Old 02-16-2022, 01:55 PM #11
Just a little bit of an update today. My wife was driving it and she said the malfunction showed up again today. When she called me to mention it, it disappeared again. It probably showed for only a few seconds or maybe minutes. It seems to me there's something wrong with connection somewhere. Here's what I will do this weekend. I will unhook the gas pedal wiring and spray the connector with an electrical cleaner.
I also noticed when I was driving it yesterday, got a message the radar cruise control turned off and turned back on.
Old 02-17-2022, 03:04 PM #12
Well that sucks. Did it happen during snowy/icy/very cold conditions?
We've been told the ABS module they ordered for our 2020 4Runner likely won't be here for another 1 to 4 weeks. That puts the truck potentially out of service for well over 30 consecutive days, potentially 40+ days. I have little faith that the ABS module will fix the issue either. We may be pursuing a lemon law buyback if the module doesn't fix it.
Also, they didn't try the brake pedal/gas technique I asked them to try.
Old 02-17-2022, 03:34 PM #13
the weather is around mid 20s but not snowing and the road is dry. the truck was very dirty though. i washed it today underneath and sprayed those salt away. sprayed the engine bay too with water to clean it. the temp is around 55 today. i'll check the abs sensor wire and see if there's some chewed wires or something.
Old 02-17-2022, 03:52 PM #14
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
many 4runners have rodent wiring soy material .. now back in the old days petroleum has wiring insulation ..
I spray silicone on the wiring harness and I use peppermint oil spray in in the bottle ..
my 4runner 2016 had rodents in the eng area and now it is no rodent issue.
many on runner forums put pictures of rodent wiring chews.. toyota dealerships cost 2500 bucks ..
catrains is offline   Reply With QuoteReply With Quote
Old 02-20-2022, 05:49 PM #15
Do you have upgraded headlights (LED or stronger halogens) or Pro LED fog lights?
abs , braking , drive , fine , malfunction
ABS, braking power low and drive start control malfunction lights Ih8fizzix 5th gen T4Rs 66 04-18-2024 06:57 PM
Help! 2020 Smart key system malfunction Ry'sRunner 5th gen T4Rs 8 11-22-2020 09:15 PM
intermittent start issue and hesitation going into drive hankd 4th Gen T4Rs 3 07-11-2019 01:42 PM
Drive side power window issue Brizz 4th Gen T4Rs 3 01-15-2013 07:40 PM
Hill-start Assist Control (HAC) malfunction? MeetJoeAsian 5th gen T4Rs 4 03-12-2012 01:21 PM
