Old 12-23-2023, 02:15 PM #46
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
They are correct, Limited is an AWD where TRD models and SR5 are 4WD. Bushing is not for AWD models
<<<< is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 08:53 PM #47
EbenezerScrooge EbenezerScrooge is offline
EbenezerScrooge is on a distinguished road
So are the limited trims not prone to the needle bearing issue? Because I feel during cold weather some sort of groan like nice at a very lower speed as I’m speeding about and perhaps even specific rpm.
EbenezerScrooge is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 08:55 PM #48
Steve40th396 Steve40th396 is offline
Steve40th396 will become famous soon enough
The company said the Limited front diffs are a different part number.
Yep, I drive a 2019 Limited Nightshade...
Steve40th396 is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 09:01 PM #49
Yes, different part number as the diff itself or as the ECG solution part number to use. And if it’s the diff a does that mean the Limited isn’t prone to this problem and it can’t occur?
I appreciate your response but it honestly doesn’t answer my question
Old 01-11-2024, 09:12 PM #50
ECG told me the Toyota Limited differential is a different differe tial than the other Limiteds and they had no solution to fix it. So, different differential, no ECG solution to fix it as they apparently have no issues in the Limiteds.
Old 01-11-2024, 09:16 PM #51
thanks. I wonder what I’m hearing then. Cold temperatures, as I’m speeding up this sound occurs I’d say between 20-40miles, appears to be coming from drivers side, almost like a growl/hum for just a short period as soon as it falls outside the speed or rpm range it dissappears..
Old 01-11-2024, 09:24 PM #52
Hard to say. Lut window down, drive througj area with a lot of concrete to attwnuate sound. Brakes on and off. See if that makes it come and go.
Left and right some times makes noise of bearing more pronounced.
4wd , dealer , engage , noise , toyota
V6 4X4 Grinding in 2wd only, needle bearing? bigonenine 4th Gen T4Rs 11 03-18-2021 02:18 AM
Limited AWD needle bearing or wheel hub? USMC0351 5th gen T4Rs 0 03-16-2019 01:20 AM
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Needle Bearing and CV Axle kremlon 3rd gen T4Rs 11 04-27-2017 09:26 PM
damaged CV needle bearing retainer krenaud33 3rd gen T4Rs 7 03-17-2015 12:00 PM
