Old 02-12-2022, 10:36 PM #1
Jeffrey_VB's Avatar
Jeffrey_VB Jeffrey_VB is offline
Jeffrey_VB is on a distinguished road
Jeffrey_VB's Avatar
Pros/Cons of Leveling Kits
Thinking about a leveling kit for my 2021 TRD ORP. Wanted to get some first hand observations from those who have had them installed.
Pros? Cons?
Other than appearance, does a leveling kit provide any benefit? Any negatives? Decreased gas mileage? Handling problems on road?
2021 TRD Off Road Premium in Midnight Black
Not Much Yet...But More to Come!!!
Jeffrey_VB is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 11:49 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
I have the Rough Country leveling kit. 2.5" front, 1" rear. The main benefit is greater ground clearance.
This is a spacer kit that fits between the top of front strut and the body mount; and on top of the rear springs. With this installation, there is no change in the length of the strut, nor the actuation length of the shock. Thus the ride is the same. Space kits that go between the spring and the spring mount do "preload" the spring and change the shock actuation length, but that is not the Rough Country set up.
Because the changed angles of the UCA and LCA, an alignment is mandatory. I have not noticed any change in handling. The front drive axles are at more of an angle, thus the life of the CV joints may be shortened. For larger front lifts, people will do a front differential lowering kit, but seldom is it needed with only a 2.5" lift
The rear shock does actuate lower on it's range, but it is possible to get extended length shocks. Because the spring is the same, and operates over the same range, there is no change to the rear ride.
Because the 4Runner has a live rear axle, a lift kit does not raise the axle, thus the lowest point becomes the rear differential. If you are concerned about that, then you need a skid plate for the rear diff. The only way to raise the rear diff on a live axle vehicle is with bigger tires.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-13-2022, 09:04 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Before you do anything I would watch this Youtube video: "4 Common Myths About IFS Lifts".
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 02-13-2022, 09:04 AM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Old 02-14-2022, 07:36 AM #5
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Pros? Cons?
Pros
Looks better
Better clearance (front side)
Cons
Worse handling if alignment/ geometry is too far off or not done properly
Rear sag when loaded can throw off front headlights (better align them after lift)
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 07:57 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Pros:
Aesthetics
Maybe approach angle?
Cons:
You wont be level when loaded with gear, bikes, or towing, you will be squatted
IMO, spend money on performance or mods that suit what you want to do in the truck, to me leveling is just aesthetics, but also it's your truck and you should do what you want. I'd get some recovery gear, sliders, skids, etc..
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 12:03 PM #7
solid videos by that dude.
Old 02-14-2022, 02:26 PM #8
FOGO DE CHAO FOGO DE CHAO is offline
FOGO DE CHAO is on a distinguished road
I just put Cornfed 1” spacers in the front. Chosen specifically because it’s top mounted and you aren’t compressing the shocks to do it. Plus didn’t want to screw up geometry too much.
Looks 100% better. Feels better driving and sitting in it as it doesn’t feel like you are falling forward all the time and diving when braking.
But if you are wanting an aggressive change obviously that won’t do it.
FOGO DE CHAO is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 08:10 PM #9
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Agreed, he gets pretty deep into suspension dynamics in an easy to understand way.
Net net: Spacer bros and folks cranking down their coilovers over 2.5" are reducing their suspension performance to worse than stock. Fine for mall crawlers but not for people actually looking to improve offroad performance.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 08:35 PM #10
Xtremluck's Avatar
Xtremluck's Avatar
Old 02-14-2022, 08:44 PM #11
people forget using OEM pivots only give you x amount of travel regardless of how fancy the stickers are. ride height changes ride quality immensely if you actually use it for off-roading.
Old 08-04-2022, 12:38 PM #12
Dri02121 Dri02121 is offline
Dri02121 is on a distinguished road
additional components
Hello,
I just got my 2022 TRD Pro and looking at leveling kits. I had a 2018 TRD premium with a 3" lift without all the proper components so it ended up starting to cost me. I would like to avoid this with the new truck and do it right this time. I just want to level the front end of my Pro. I have read mixed reviews about if I need to add upper control arms.
Do I need new upper control arms if I add spacers or spacers plus new springs? Any other components that are recommended to be replaced if I level the front end?
Thank you
Dri02121 is offline   Reply With QuoteReply With Quote
Old 08-04-2022, 01:26 PM #13
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Originally Posted by Dri02121 View Post
Hello,
Thank you
get the Eibach TRD pro lift springs made specifically for the fox setup. 4 springs. UCAs...optional.....may be needed to get better alignment, especially if going with bigger tires.
That is my setup with Dirt King UCAs.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 08-04-2022, 02:58 PM #14
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
Like said, figure out your primary use/goals and set it up for that. I removed all my car-like springs on my excursion to properly tow my travel trailer and replaced with F250 springs. Loaded and near 10k it sits level and all the weights are balanced. When it's not hooked up it sits like every F250/350 you see empty. It's all about trade-offs.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
installed , kit , leveling , pros , pros/cons
Pros and cons fo leveling spacer vs adjustable Bilstein fron shocks? spetka 5th gen T4Rs 18 01-13-2018 03:18 AM
Pros/Cons of 1st gen vs 2nd gen jmitchell79 Classic T4Rs 27 11-30-2013 05:58 PM
3.0 pros and cons? Lil Evil1 Classic T4Rs 12 06-06-2012 03:02 PM
pros and cons 3rd vs 4th gen steelynorm General Discussions 6 12-24-2011 12:46 AM
pros and cons of 4 cyl 2wd? JorgeSantos 3rd gen T4Rs 5 02-21-2006 05:25 PM
