Old 02-22-2022, 03:58 PM #1
deafboy deafboy is offline
deafboy will become famous soon enough
My Dasaita Headunit Experience/Tips
Had shared this over on Reddit but thought it'd be worth sharing here as well. Since I've had my 4Runner I've been searching and have seen a lot of people asking about the Dasaita headunit and figured I'd throw in my $0.02 since I haven't seen too many people use the stock GPS antenna and I haven't seen anyone use the XM
Antenna.
Have had my Dasaita Headunit for a bit over a month now, overall, I like it, but it's definitely not perfect. At full price I think I'd be a bit disappointed, but got it as an Amazon warehouse deal for $464 and overall does what I want, better screen and Android Auto. Paired it with TWO of this kit from crutchfield/Amazon and this adapter to utilize the stock GPS antenna as well as the stock XM antenna for WiFi paired with this adapter. The use of the XM antenna for WiFi isn't needed but I figured if it's there, I might as well use it. Fortunately Toyota went a bit wide on the frequency range since technically WiFi shouldn't work on an XM antenna, but it's been great for me so far, little bit better range than the tiny stock antenna that comes with the head unit, I'd imagine mostly due to location for reception.
Install was super simple, followed this video and was able to just take my sweet time and do a clean job. The trim was a better match than I was expecting, it does look pretty OEM.
My biggest complaint is the screen is pretty bright even at the lowest setting, took some getting used to for night driving, but not a huge deal to me and there are some work arounds if you don't mind playing around. I ended up adjusting the settings within the headunit's factory settings (code 126 to access) and then utilized this app to get it even dimmer. I ended up installing a different launcher to adjust the look.
The wireless Android Auto is hit or miss, I personally just use wired since my phone just sits in my dock anyways.
Having Google Maps without a phone is nice, although the layout is a bit weird given the wide screen. But great in a pinch. I rarely have had to use that though since I tend to always have my phone on me.
One thing to note if you plan on using wifi/bluetooth a lot, it seems that since it only has the single antenna you can really only use one at a time effectively. If you try to use both at the same time it can be a bit spotty, it can work, but it can be a bit more hit/miss. This was true with the stock antenna and the car's XM antenna.
The steering wheel controls are great, and honestly, that alone was worth the upgrade to me, being able to move to the next track and pause/mute was more intuitive.
The knobs aren't as nice as the ones on the OE unit, they're just hard plastic but I never use the knobs, I use the steering wheel controls so that hasn't bothered me, but definitely worth noting.
Since I didn't use the kit's GPS and I didn't install a front camera, the cabling was actually pretty minimal which was nice.
I however did opt to utilize all the USB ports and HDMI port. I had the blank spots in the glove box since my stock USB and 12v are on the center stack. Decided to populate those to better utilize the ports the Dasaita unit offers. Have this USB port in the 12v slot and this USB/HDMI adapter in the smaller blank button next to it.
For what it is, it's a pretty nice kit. It's not the fanciest most high-tech kit out there. But I definitely consider it an upgrade over the stock unit.
If you're interested in anything in particular, let me know, happy to answer any questions / share and pics/vids you may want. Still learning so might not have all the answers, haha
deafboy is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 12:18 AM #2
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
What do you have the HDMI port for?
The HDMI is output on the head unit.
If you want input I used an adapter on the RCA cable to create a HDMI input that I use for an iPhone digital AV adapter.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 02:25 AM #3
I don't actually utilize the HDMI at all. It just happened to be one of the few USB that filled that slot that I liked. I was initially going to get a dual USB for it but ended up not liking any of her options I found.
Old 03-03-2022, 07:13 PM #4
JD9827 JD9827 is offline
JD9827 is on a distinguished road
Steering wheel settings
I installed this unit in my 2016 Runner, but cannot get the Steering wheel functions to work. Went to settings, and I see that under the CANBUS option it is selected to NO. When you pull down the Menu it gives you over 100 options to choose from...Do i need to select one of the Toyota options....if so, which one?
JD9827 is offline   Reply With QuoteReply With Quote
Old 03-03-2022, 08:54 PM #5
Got it working.....Looks like i needed to choose the CAN 08Toyota RAV4Corolla(Simple) option and reboot. It then let me choose wheel keys and select each button function.....Now i need to figure out why my Radio signal fades in and out, and most channels wont even register. Antenna is seeded properly.....any thoughts?
Old 08-15-2022, 02:40 PM #6
4runnerokc 4runnerokc is offline
4runnerokc is on a distinguished road
2016 4Runner - Issues W/Backup Cam & Steering Controls
Team, I'm experiencing some issues with my backup camera and steering wheel controls. Here's a YouTube video overview of the setup.
As previously suggested, I set my Canbus to "CAN 08Toyota RAV4Corolla(Simple)"
As a reference, here's exactly what I purchased from Amazon.
Any advice would be GREATLY appreciated. Thanks in advance!
4runnerokc is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 05:10 PM #7
Cej255 Cej255 is offline
Cej255 is on a distinguished road
I have the same head unit and mine matches yours. Did your unit come with the canbus module for the radio harness?
Cej255 is offline   Reply With QuoteReply With Quote
Old 04-04-2023, 01:55 PM #8
oldschoolandrew oldschoolandrew is offline
oldschoolandrew is on a distinguished road
A couple weeks ago I just bought my first 4Runner, a 2011 Limited.
I found the Dasaita head units and purchased one for my 4runner via amazon.com
I'm just wondering how you know which canbus setting to choose in the settings? I'm getting no vehicle data showing up in my headunit like I thought might.
Thanks!
oldschoolandrew is offline   Reply With QuoteReply With Quote
Old 04-04-2023, 03:17 PM #9
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Thanks!
I used this for my 2011 4Runner SR5 aftermarket head unit to retain steering wheel, handsfree functionality, and optional NAV data input. It comes with an OBD-2 V3 2-pin connector with simple straight forward instructions.
PAC RP4.2-TY11 Wiring Interface
PAC RP4.2-TY11 Wiring Interface Connect a new car stereo and retain factory JBL system, steering wheel controls, and aux input in select 2005-19 Toyota, Lexus, and Scion vehicles at Crutchfield
RP4.2-TY11 Owners Manual
https://images.crutchfieldonline.com...541RP4TY11.PDF
Metra AX-TOYUSB-2 USB Port Cable (to utilize the USB in the glove box)
Metra AX-TOYUSB-2 USB Port Cable Allows you to connect the factory USB port on select 2010-up Toyota vehicles to a new car stereo at Crutchfield
Everything works like factory. You can also buy a direct replacement mic with an 1/8th" jack that works better than the stock one.
Enfig MIC-TOY1 – Toyota and Lexus Factory Fit Custom Microphone
Enfig MIC-TOY1 – Toyota and Lexus Factory Fit Custom Microphone – Enfig Car Stereo
Don't even get me started on the Party Mode rabbit hole you'll go down with this truck.
Cheers!
My Dasaita Headunit Experience/Tips-g541rp4ty11-f-jpg  My Dasaita Headunit Experience/Tips-g120toyusb2-f-jpg  My Dasaita Headunit Experience/Tips-enfig_mic_toy1-jpg
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 08:52 AM #10
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
thank you for this write up. i have the same unit in my 4runner. How did you get around from not using the wirelss android auto to plug-in android auto?
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 11:06 AM #11
My Dasaita head unit came with a wiring harness that fit my vehicle and all I'm missing is any vehicle data that should be received.
I'm also curious about what a couple connections from my stock head unit that aren't being used with the Dasaita harness and if one of these could provide GPS as I haven't yet plugged in the small GPS unit that came with the head unit.
Cheers!
My Dasaita Headunit Experience/Tips-pxl_20230406_145221091-mp-jpg
Old 04-06-2023, 11:30 AM #12
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
1 - XM Radio connector if equipped
2 - GPS NAV Antenna connector (the smaller of the two male leads)
I have seen an antenna adapter online somewhere that combine the two Antennas for aftermarket HU's wanting to maintain NAV function. The OB-2 connector should transmit GPS telemetry to the HU if supported.
Old 04-06-2023, 11:41 AM #13
Thank you! I was wondering if one of them was GPS Antenna connector.
I'll try to see if I can find an adapter to get it to plugin to my Dasaita head unit.
Old 04-23-2023, 11:43 PM #14
yeti73 yeti73 is offline
yeti73 is on a distinguished road
Antenna.
I had difficulty figuring out how to wire up my 2015 limited bc of the stereo system.
-Biggest complaint is that the radio is super loud even on the lowest setting. I went into setting and decreased the volume on each speaker, but it is still super loud (could have wired it incorrectly, but was the only way i could figure out to get sound in all the speakers).
Sound if fine with apple car play/my phone
-Wireless carplay works pretty well for me especially considering any other stereo with this is about 1200.
yeti73 is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 03:32 PM #15
Interesting, I haven't had any volume level issues. Granted I really only use Android Auto or the headunits YouTube app.
Long term, I am not exactly sold on this Dasaita unit. The longer I have owned it the more frequently I get random bugs. But I also haven't seen any other options that I like
antenna , bit , dasaita , pretty , stock
New Dasaita Head-unit jony.lisa 5th gen T4Rs 132 04-24-2023 08:06 PM
Anyone using the Dasaita head unit? rhadam 5th gen T4Rs 41 11-07-2022 09:47 AM
Dasaita head unit is out. Similar to T9 Pikapp168 5th gen T4Rs 23 12-05-2020 03:08 AM
SHOW ME YOUR TIPS.....pics of what exhaust tips u guys are runnin 4jogger 4th Gen T4Rs 28 02-03-2018 02:05 PM
My experience and tips to install front Billstein 5100s tony_4r 4th Gen T4Rs 8 10-30-2013 12:03 AM
