01-11-2024, 09:00 PM
#91
Originally Posted by Firesq14
I run the geolander ATs
Do you have an update on wear, noise, mileage/ tread life and gas mileage?
So these are MT's
I think they performed well for MT's that saw mostly street use with some off road use. After about 15k miles ( I think) they started to require balancing more often; they would wobble a bit. The tread wore evenly, they handled amazing in mud and snow, and weren't to loud for MT's. I think I removed them with about 22k miles or so.
I don't pay much attention to MPGs
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
01-13-2024, 11:32 AM
#92
I added ARB's premium Hi Lift jack holder to the side of the ARB Base Rack.
The look is very cool, and makes the Hi Lift super easy to access; much better than the previous way I has it mounted on the OEM TRD rack.
This kind of stems away from the OEM+ look I like, but its growing on me and I think I'll keep it this way.
04-05-2024, 12:58 PM
#93
Did a little more fender trimming and added High Clearance rocker caps from @MinWin3D
Great quality and simple install. No more rubbing the rocker caps and the look is OEM.
High Clearance Rocker End-Caps
04-07-2024, 03:15 PM
#94
Real Name: Adam
Real Name: Adam
those are pretty nifty
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
04-08-2024, 10:08 AM
#95
04-15-2024, 12:14 PM
#96
Sometimes its the little things.
Ever since I moved the jack from the top of the old TRD rack to the side of the new ARB rack, it rattled like crazy. The old Hi Lift handle keeper didnt work due to the way the ARB jack mount held the handle close to the body of the jack. After trying a couple different handle keepers, I landed on this one that worked out perfectly; no more rattles! $22 and 30 seconds of work lol.
I do a lot of DIY at home, and actually use my rack. Rather than hooking straps to the outer edge I added these ARB eye loops. This rack has a ton of small accessories like this available
04-22-2024, 01:22 PM
#97
Got the new front valance installed. No hybrid bumper yet; sticking to the OEM look as long as possible.
04-25-2024, 01:15 PM
#98
Added an ARB Roller Kit to the back of the ARB Base Rack. This allows you to load things onto the rack without scratching it up. Took all of 3 minutes to install
05-02-2024, 03:22 PM
#99
These have been sitting in my garage for almost 2 years but finally got around to installing the adjustable Dobinsons rear sway bar links.
