Old 03-01-2022, 02:22 PM #1
Runnin4MO Runnin4MO is offline
Runnin4MO is on a distinguished road
Eibach Load-Leveling System: how do you adjust it?
Hey all,
So I installed the Eibach Load-Leveling System, +400lbs version with their shocks about a year ago. +400 version because I was planning on getting a full steel rear bumper/tire carrier.
When I originally installed the kit I had the shocks disconnected and everything was nice and easy to turn by hand and adjust during install. I set it and it was good to go height wise after completing the install.
Well I finally installed the new steel bumper and tire carrier a couple months ago, so I need to adjust the Load system higher to compensate because now the rears sagging giving me negative rake.
I jack up the rear today. try by hand, it's not budging... I use the little sh!t piece of aluminum stock that they give you as the "adjustment tool" to stick in the holes to turn it. The aluminum is so soft it bent like a damn bendy straw. Completely fu@king useless. I have a couple very large pipe wrenches but neither have long enough teeth to get around it to grip.
Any ideas, or what have you guys done to adjust this? I dont want to rip the wheels off and take apart the damn shocks again just for this "easy adjustment".
Thanks all!
Runnin4MO is offline   Reply With QuoteReply With Quote
Old 03-02-2022, 12:58 PM #2
M_RED M_RED is offline
M_RED will become famous soon enough
For me the first time I had to jack up the rear end so both tires are off the ground, and I then disconnected one sway bar link. After that it was pretty easy to do. since then, I added longer rear sway bar links and I don't need to disconnect them any more...
Essentially you need to take all the pre-load off the springs..
Eibach 1.6in LIft springs and 0.25 in spacer in the front
Eibach +200lbs load leveler system in the back
RSG Angled Sliders
M_RED is offline   Reply With QuoteReply With Quote
Old 03-02-2022, 01:34 PM #3
icyhotahs icyhotahs is offline
icyhotahs will become famous soon enough
I used a jack stands on both sides. Used my jack under one brakeset to leverage the droop. Used pick drivers and silicone spray to get the plates movings.
icyhotahs is offline   Reply With QuoteReply With Quote
adjust , installed , shocks , system , turn
Eibach Load Leveling System (aka height adjustable rear) Ryan at Eibach 5th gen T4Rs 69 04-17-2022 07:34 PM
Eibach 5th Gen Rear Load-Leveling Kits TotalAutomotiveLV 5th gen T4Rs 2 01-26-2021 09:47 PM
Bilstein 5100/ eibach springs OR Eibach pro truck lift system? T4R416 5th gen T4Rs 28 12-08-2020 05:21 PM
Eibach Pro-Truck Sport Shocks (Leveling Kit) OC4X4 5th gen T4Rs 6 07-09-2017 01:12 AM
Load leveling Airbag / Air shock chrisdowling84 5th gen T4Rs 26 04-27-2014 07:22 PM
