Old 03-04-2022, 05:04 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Driver Lean Replacement Shocks
I know driver side lean is covered heavily on this forum and across other Toyota trucks, like the Tacoma for a long time now, but has this happened AFTER replacing an aftermarket lift with a different brand?
I previously had the Bilstein 5100 shocks installed with Toytec 2” coils in the rear. Had this setup for about 3 years and one started to develop a slow leak so I replaced just the rear shocks with Dobinsons. Now I notice a driver side lean (didn’t do this with previous setup). I took a quick measurement and the driver side is about 3/4”-1” shorter compared to the passenger side. Only thing I can think of is the single sided drawer I have on the driver side, but this is the same drawer I used when I had my previous suspension.
Chilow is offline   Reply With QuoteReply With Quote
Old 03-04-2022, 06:33 PM #2
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
The correct length and travel shocks installed correctly do not determine rear ride ride height unless they are defective(sticking,binding). The rear springs determine ride height.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 03-04-2022, 06:36 PM #3
That’s what I thought as well, which is why I’m confused because I kept the rear springs. The only thing I changed out were the rear shocks.
Old 03-04-2022, 07:14 PM #4
harper7's Avatar
Real Name: Gary
harper7's Avatar
Real Name: Gary
That is strange. Did you take the rear springs out? Sometimes you can swap springs left to right as the spring rates are rarely EXACTLY the same and have a range . Or sometimes the rear springs aren't seated correctly.
You can also add a trim pack spacer to the lower side spring ,like this one ...
150PR10 - OME 10mm Rear Trim Spacer
2001 Tacoma TRD 5sp
Old 03-04-2022, 07:17 PM #5
Nope. I was able to remove and replace the rear shocks without touching any of the other suspension components. Literally just removed the bolt holding the top of the shock and the bolt holding the lower. Snugged lower bolts in the air and torques on the ground.
Old 03-04-2022, 07:37 PM #6
harper7's Avatar
Real Name: Gary
harper7's Avatar
Real Name: Gary
Might be the shocks then? Try it without them or with the bottoms loose from the axle .
I know that top shock nut is a bee atch .lol
2001 Tacoma TRD 5sp
driver , lean , rear , shocks , side
Driver Side Lean 4Runnin4Fun 5th gen T4Rs 19 01-29-2023 11:52 AM
Driver side lean octanejunkie 3rd gen T4Rs 25 11-15-2021 09:31 PM
Driver side lean? jmv7680 4th Gen T4Rs 13 07-31-2019 03:36 PM
Front driver lean jonb2 4th Gen T4Rs 26 10-22-2015 07:58 PM
driver side sag/lean jmeeller 3rd gen T4Rs 18 12-01-2014 11:36 AM
