Old 03-06-2022, 05:22 PM #1
EZBR. EZBR. is offline
EZBR. will become famous soon enough
Well, It started with just ABS Light, VSC Light and A Flashing Multi-Terrain....
so i thought... oh. probably a ABS Wheel sensor.... she drove fine home... went inside got my TechStream laptop and plugged her in... spend the next 5+ hours trying to get them to talk but no bueno.... while idling trying to get TechStream to work... the car starts freaking out... every light on the dash lit up like it was a Land Rover, Tach started bouncing, the gear indicator went blank, Range and outside Temp displayed 'E'....... I'm stumped. I have no idea what's going on
unplugged the battery overnight, put a trickle charger on the battery so it was fully changed, cleaned all the terminals, unplugged ALL my aftermarket accessories, unplugged my aftermarket LED's, unplugged the ABS Module (Just to get it to stop freaking out), checked every fuse with a multimeter, found a lil water inside the tow trailer plug, cleaned that and took out all the fuses and relays associated to it.... I can't figure it out
ANY input from you guys would be greatly appreciated...
Could this still be a friggin speed sensor spazzing out the ECU's???
EZBR. is offline   Reply With QuoteReply With Quote
Old 03-06-2022, 09:10 PM #2
4Energy 4Energy is offline
4Energy is on a distinguished road
Did you actually replace the ABS sensor/wires? That might do it. Fixed my similar issues years ago.
4Energy is offline   Reply With QuoteReply With Quote
Old 03-06-2022, 09:31 PM #3
No i didn't, I wanted to dig around in techstream and try to figure out which sensor it was. they all look fine physically and the wires aren't damaged :S I'll have to go in with a multi meter or something and test them all out I think.
Old 03-09-2022, 03:50 PM #4
So I took it to a toyota repair shop... looked at it for 30 mins and said there's nothing we can do. Our scanner doesn't communicate with your suv, come pick it up im aoo bummed...
I guess dealership is next best bet
Old 03-10-2022, 01:59 AM #5
djeepin djeepin is offline
djeepin is on a distinguished road
Trans selector switch probably bad. Check by un-plug it.
djeepin is offline   Reply With QuoteReply With Quote
Old 03-10-2022, 08:19 AM #6
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
This.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-11-2022, 12:43 PM #7
Oh?
See, that wouldn't even cross my mind because i wasn't having any shift issues.. but at this point I'll try anything.
I will give it a try later on today and report back.
Old 01-12-2023, 02:15 PM #8
Brownfaux Brownfaux is offline
Brownfaux will become famous soon enough
I'm fighting this issue now as well. Could not pull codes either, but the stars aligned somehow and I got several. The one of note, that resulted in the most search results was C1425.
Appears to be related to water intrusion at the driver side firewall. I'm still researching and reading and poking around. At this point it's intermittent. Problem started after sitting under snow and rain for a week and having a low battery. Driven plenty in rain prior to this, but not freezing.
It went away after drying out, but then I drove in the rain a day ago and now it's back today.
Brownfaux is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 04:54 PM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
We had every idiot light come on, including the battery charge light, when the alternator went out. Eventually dash went dark and would only come on when headlights were turned off. Fortunately we were just 3+ miles from home. Installed a new Denso OEM alternator and no issues since.
CutthroatSlam is offline   Reply With QuoteReply With Quote
aftermarket , battery , cleaned , light , plugged
C1425 Code: ABS, Trac Lights solid, Multi-Terrain Light Flashing Lost27 5th gen T4Rs 3 01-11-2023 02:31 PM
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
[Need help] Warning lights? Multi-terrain & Four-wheel drive indicator light flashing robkh1984 5th gen T4Rs 23 06-15-2019 11:20 AM
ABS, Slip indicator and Multi-Terrain Light Tuc4R Engines / Suspension / Wheels / Tires / Audio / Accessories 5 06-02-2018 10:11 PM
TPMS Light Randomly Started Flashing thirstyturtle 4th Gen T4Rs 20 05-02-2016 06:51 PM
