Old 03-11-2022, 12:30 PM #1
T4Rrunning's Avatar
T4Rrunning T4Rrunning is offline
T4Rrunning is on a distinguished road
T4Rrunning's Avatar
Choosing 285's - LT load range C or Standard Load? Tire Recommendation
I am looking at 285's and have narrowed it down to 2 tires
Toyo Open Country AT3 load range c - 55lbs
Open Country A/T III | The All-Terrain Tires for Trucks, SUVs and CUVs | Toyo Tires
Mickey Thompson Baja Boss AT standard load range- 48lbs
Mickey Thompson | Baja Boss A/T
I have a 2021 TRD Pro and not sure if these will fit on stock suspension. Since they do a bumper and fender trim on them at port. Otherwise I am prepared and ready to add the eibach pro springs for 1.4" front lift and 1" rear.
My question is are stanard load tires like the MT baja boss strong enough for off-roading/camping/overland? Keeping in mind I may have to air down and live on the westcoast (california trails, utah trails, arizona trails)
Thanks in advance for your feedback!
T4Rrunning is offline   Reply With QuoteReply With Quote
Old 03-11-2022, 12:57 PM #2
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
What bumper & fender trim do they do at the port? I've seen no differences between a Pro and my ORP (when it was stock) other than increased front clearance due to the Fox struts & Pro springs (making it about 1in taller in front).
As far as 285s on stock height, you're going to rub, more than likely at full lock and when articulating. So, if you're mall crawling then you won't have too much issue. Before I trimmed a bit and got rid of mud flaps, my 285s rubbed at full lock while articulating... and mine is lifted 3in and a BMC.
As far as load rating, if you're not going to be doing rock crawling on the regular, go with C load. I'm not a huge fan of airing down and hitting the trails on SL rated tires. If you are going to be doing regular rock crawling or your trails have a lot of sharp rocks, then I'd go with the E load for the extra security of a thicker sidewall.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 03-11-2022, 01:13 PM #3
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
op
I have 20 pro with the 21 suspension running 285/70 duratracs. Yes you will have some minor rub at full lock....I was able to get 95% of that fixed with a heat gun and reforming liner. No bmc was needed. I just installed the Eibach lift springs and gained 2 inches up front and 1 in the rear. After I installed slim bumper and winch (130ish lbs) I lost an inch up front, so a net gain of 1. anyways, no rubbing, and no bmc.....all mods have been done with heat gun.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-11-2022, 02:09 PM #4
T4Rrunning's Avatar
T4Rrunning's Avatar
It seems like the C range is a happy medium between tires in 285.
I have heard pretty good things about the Toyo open country at3, I guess the only downside is they are not as aggressive looking as some other tires.
They cut the inside of the front bumper a bit and push the fender liner forward a bit on the TRD Pro models.
Old 03-11-2022, 02:10 PM #5
T4Rrunning's Avatar
T4Rrunning's Avatar
Originally Posted by lewdog998 View Post
op
This is good to hear. Honestly I would probably only run it on stock suspension for a bit until I receive the Eibach pro springs and can get them installed probably about a week or 2 max after the tires.
baja , boss , load , pro , trails
Load Range C vs Load Range E rated tires BobsTrail 5th gen T4Rs 63 07-24-2020 12:10 PM
load range c bfg k02 kdub351 5th gen T4Rs 4 08-16-2017 01:24 AM
What PSI for 275 70 17 K02's Load Range E Moto69Joe Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-16-2016 11:58 PM
B load range on my 4th gen Token13 4th Gen T4Rs 2 05-11-2014 03:59 PM
285/75/R16 BFG Load Range E Only? Baja Runner 3rd gen T4Rs 14 09-17-2011 01:37 PM
