Old 03-24-2022, 04:48 PM #1
Partywaggin Partywaggin is offline
Partywaggin is on a distinguished road
No 255/75-17 AT Tires Excite Me
I want to run 255/75-17 but none of the AT tires excite me. I won't run MT or E-load tires because I want decent comfort on the pavement and don't offroad enough to justify them in southern AZ.
I have the Eibach Stage 1 lift with the factory front springs on the top perch for what should be a 2.5"/1" lift.
I don't want to run 285/70's due to the weight and rolling resistance penalties. Same for 275/70's. The weight and potential rubbing issues turn me off of the 255/80's.
In 265/70's I've narrowed it down to the Grabber ATX C-load and Rugged Treks. Feels like I can't go wrong with either as they are relatively comfortable and quiet, decent rain performance, beefier than an SL, but not boat anchors like an E-load, have good warranties and should be under $1k after install, taxes, disposal, etc.
Is there a 255/75 tire you can talk me into?
Partywaggin is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 05:16 PM #2
Ascole Ascole is offline
Ascole will become famous soon enough
Goodyear Duratracs come in 255/75/17 in SL load range
Ascole is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 05:35 PM #3
uh0h50 uh0h50 is offline
uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about
If you can wait until May, it looks like the BFG Trail-Terrain should be available in 255/75, but will be SL. I'm not so sure that a C load is necessarily needed if it's mostly pavement driving that you are doing.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 06:04 PM #4
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
What's wrong with SL load? I have SL ATX's and I'm not exactly kind to them. They've done fine aired down to 18-20 PSI when necessary. Next set will be 255/80 E-loads. I think the "E-rated beats you up" is overblown on most tires.
91foxbody is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 06:26 PM #5
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I’ve owned the Yokohama Geolandar A/T and the older Firestone Destination A/T (not the new A/T2), and I was happy with both.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 11:31 PM #6
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
The KO2's in a C load only weigh 51 lbs each. I have Wildpeaks in a SL rated 285 that weighs 51lbs.
I had 275/70-17 KO2's in a E load and they weighed 57 lbs and road a little rough. Personally, I would go 285's.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 12:42 PM #7
Thanks for the suggestions, everyone!
Thanks for the suggestion, but everything I read says they get loud quickly, so I was avoiding them for the wife's sake.
Do these do better in the rain than the KO2? That's my hangup with the BFG's is the rain performance. Too many anecdotes of them scaring people sh!tless in the wet! Plus I had a set on my previous vehicle (can't remember the model) and they wore really funny in the end despite regular rotations.
Our trucks at work run the 265/70-17's with E-load tires and they are kidney crushers on anything but smooth pavement. I'm sure part of that is the leaf springs too. Plus I'm trying to avoid the weight penalty on E-load's to keep the MPG's reasonable.
I'm not opposed to SL's, but since there's not a huge weight penalty in the ATX's for going to the C-load, I thought it would be better long term, try to split the difference.
I haven't ruled out the Firestone XT's but there just doesn't seem to be a lot of info about them. They're C-Load, seem like a hybrid that leans AT vs MT. Weight is good at 40lbs.
Thanks again!
decent , lift , run , tires , weight
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Tires tires tires Maxxis Trepador VS Goodyear MTR KaliKid General Discussions 3 11-18-2015 11:44 AM
2015 Trail edition 18"tires and Cooper Tires rubbing xtreme-24 5th gen T4Rs 5 11-29-2014 11:11 AM
Suggestions on snow tires or all terrain tires for a 2002 2WD 4Runner Limited? sienna221 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-14-2014 03:39 PM
Upgrade Tires, CV Boots are now leaking after upgrading tires and need advice. AZ4runner08 4th Gen T4Rs 20 02-16-2014 06:21 PM
