Thanks for the suggestions, everyone!
Originally Posted by Ascole
Goodyear Duratracs come in 255/75/17 in SL load range
Thanks for the suggestion, but everything I read says they get loud quickly, so I was avoiding them for the wife's sake.
Originally Posted by uh0h50
If you can wait until May, it looks like the BFG Trail-Terrain should be available in 255/75, but will be SL. I'm not so sure that a C load is necessarily needed if it's mostly pavement driving that you are doing.
Do these do better in the rain than the KO2? That's my hangup with the BFG's is the rain performance. Too many anecdotes of them scaring people sh!tless in the wet! Plus I had a set on my previous vehicle (can't remember the model) and they wore really funny in the end despite regular rotations.
Originally Posted by 91foxbody
What's wrong with SL load? I have SL ATX's and I'm not exactly kind to them. They've done fine aired down to 18-20 PSI when necessary. Next set will be 255/80 E-loads. I think the "E-rated beats you up" is overblown on most tires.
Our trucks at work run the 265/70-17's with E-load tires and they are kidney crushers on anything but smooth pavement. I'm sure part of that is the leaf springs too. Plus I'm trying to avoid the weight penalty on E-load's to keep the MPG's reasonable.
I'm not opposed to SL's, but since there's not a huge weight penalty in the ATX's for going to the C-load, I thought it would be better long term, try to split the difference.
Originally Posted by ads2539
I’ve owned the Yokohama Geolandar A/T and the older Firestone Destination A/T (not the new A/T2), and I was happy with both.
I haven't ruled out the Firestone XT's but there just doesn't seem to be a lot of info about them. They're C-Load, seem like a hybrid that leans AT vs MT. Weight is good at 40lbs.
Thanks again!
