Old 03-25-2022, 11:56 PM #16
Pavement Tested Pavement Tested is offline
Pavement Tested will become famous soon enough
Originally Posted by ldchien View Post
Sorry for the delay. FedEx tends to hit me the last part of the day (or so it seems)
Arrived, perfect shape. Quality seems good. Hilariously came with trd emblems but doesn't have a cut out. I probably won't install these
Mine also came with an extra set of hardware in a gallon ziploc bag. Seems like it was a return or something.
I added the hardware but unnecessary. The setup here is wrong. Spacers go towards the front
I reused old hardware towards the back of the vehicle. Included hardware was too long. Perfect for front with spacers though
Worth the $180 to me. Very happy with it
Solid feedback. Just what I was looking for. I guess I'll be ordering one in the very near future. Thanks for sharing.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
Pavement Tested is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 09:32 AM #17
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by repo View Post
t has a diff drop and some sort of skid spacer getup to compensate. Get your self a a small metal punch, good drill bits (those gold Milwaukee ones at HD are nice), a metric thread chaser/cleaner kit and some stainless bolts (M8x1.25 I think but have to check). And a tube of anti-sieze
The TRD skid plate mounts with M10X1.25 (fine thread) bolts: TRD Skid Plate Mounted w/ Studs 2010-2021
Most of the other skid plates are M8X1.25
fkheath is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 11:53 AM #18
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Or RTD emblems according to their lawyers I bet. That is pretty hilarious though.
Looks really good especially with the silver lower bumper like that.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-01-2022, 03:02 AM #19
So, I ordered the same skid plate as @ldchien off Amazon for $180. Just took delivery of it today and I gotta say I'm pretty impressed so far.
It's painted or primed, can't decide which but it is not bare aluminum. It's thick. Like 1/4" thick. It's heavier than I thought it would be. I'm betting it's heavier than the OEM plate. The hardware looks to be galvanized which is nice, but I still may swap it out for stainless. The instructions are pretty good and in plain English not that this is a difficult installation part where detailed instructions are needed. The only part I'd say is they don't tell you which bolts to use the spacers on but that's been covered previously in the thread. Mine didn't come with the TRD letters which is fine by me, wasn't going to use them anyway. I feel like this thing could take a pretty good whack and be ok.
I picked up some spray-on 3M undercoat to make it black that I'll start applying tomorrow and will update this after the installation.
Old 04-06-2022, 01:55 PM #20
Ok, so I have an anomaly and hope y'all can shed some light. The weather has been crap so I haven't been able to crawl under the truck and figure out what's what.
The plate I ordered came with 4 bolts to mount it that are M10x1.25 and about 45mm in length. The remnants of fasteners I removed to take off the OEM plate are varying lengths due to being sheered and mismatched but are M8x1.25.
What size are the OEM skid plate bolts? Just the 4 that actually hold on the plate, not the ancillary ones for the plastic air damn? All I have been able to find is that they're M8x1.25 and 20mm long. I've looked them up by part # and don't get the specs on any parts website.
@ldchien , you said you only used 2 of the bolts and the spacers that came with it because the other 2 were too long. That's fine but did you have an issue with size other than the length?
Thanks.
Old 04-06-2022, 02:13 PM #21
ldchien ldchien is offline
ldchien is on a distinguished road
I'll be honest in that I have no idea on the actual bolt dimensions, but this plate does not mount to threads of the original bolt holes. It mounts to the bolts of the frame support which will need to be removed. I pulled this image from this site:
Car Trim Home TRD Skid Plate Review & Install For 5th Gen 4Runner
I used the bolts and spacers included with the plate on the 2 bolts closest to the radiator. I reused the existing frame support bolts for the rear.
ldchien is offline   Reply With QuoteReply With Quote
Old 04-06-2022, 02:39 PM #22
Ooohhhh! Frickin' LIGHT BULB! Thanks a ton. I was very confused looking at the stuff I pulled off and what I was sent. The instructions make some more sense to me now as I had an assumption that the new fasteners went where the old ones went. Looking at it in that pic, the spacers make sense now too.
Old 04-08-2022, 02:20 PM #23
The saga continues...
This plate is not compatible with a diff drop...
Turns out, my rig has a diff drop and I didn't recognize what it was...being new to a vehicle sucks...
Now on to finding spacers that will drop the rear bolts of the plate enough and deciding if I want to add a spacer for the front bolts
Old 04-09-2022, 05:08 PM #24
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
Can I suggest instead of spending hours trying to get the cheapest rip off copy of an already sub par design to work, that you contact one of the many reputable USA made manufacturers of aftermarket armor for our vehicles...
Most other skids will have access doors for oil changes so the plate doesn't have to come off with each oil change.
Here's one of many threads dealing with Diff Drop / Skids issue:
Diff Drop and skid plate
Originally Posted by teotwaki View Post
Some skid plates such as RCI's design have a profile with a "bulge" that allows diff drops
Skid plate thread Consolidated 5th Gen Skid Plate Info Thread
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 04-09-2022, 06:10 PM #25
Thanks for the input. Not interested. As stated in post#1, the Amazon sourced plate is more than satisfactory for my application. PO installed equipment is my obstacle, not a so-called sub-par product. The diff drop installed on my rig is incorrectly done to begin with and is the source of my initial issue. It is being resolved.
bolts , front , oem , plate , skid
Missing Skid Plate kavalis 4th Gen T4Rs 11 03-15-2020 07:21 PM
Front Skid Plate - Missing Hatches/Doors BleednBlue 5th gen T4Rs 9 11-18-2018 11:51 AM
HELP: lower Control Arm Adjuster Plate Sheered CrazySte Problems & Warranty Issues 7 08-17-2018 06:29 PM
Is it missing the front skid plate? karyins 4th Gen T4Rs 2 09-29-2016 09:33 AM
Missing front Skid plate? Hit a deer. DiskDoctr 4th Gen T4Rs 1 12-11-2006 02:22 PM
