Old 03-25-2022, 03:27 PM #1
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
Towing a TRD PRO behind a RV
I plan to do a road trip in the fall. The thinking is to rent an RV and explore Washington,Oregon, and Alaska
Does anybody have experience towing a TRD PRO behind an RV..........?
Thanks
.mc
Mark4runnar is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 05:26 PM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Can not do it with a Toyota. The rear wheels turn the transmission even with the transfer case in neutral. Removing and replacing the drive shaft may be too much of a hassle.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 05:45 PM #3
Thanks = I guess I should have known that.
Old 03-25-2022, 06:00 PM #4
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
When did this start? Some time ago, both Jeep and Toyota both used New Venture / New Process transfer cases and Jeeps could be towed flat.
I’m sure there’s some specifics but is this a 5th Gen thing, a specific transfer case (2WD/H4/L4 vs H4F/H4/L4 of the Limited) or…?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 07:02 PM #5
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
The problem is that when you put the transfer case in neutral, The location where it disconnects the main input shaft is downstream of where the oil pump is in the transfer case. So it doesn't spin the oil pump. And the fluid level and the transfer case is not full enough at the normal fill level to oil the bearings of the output shaft. So you end up spinning the output shaft driven by the rear axle without oil. You can do it for short distance is no problem, you can't do it for long distance without risking damaging those bearings in the output shaft of the transfer case.
It's no problem if you disconnect the rear drive shaft. It's only four bolts at the flange. Front shaft can stay connected. You can probably do it in about 2 minutes with the right tools. And then you'll need to strap up the shaft.
More info here: https://www.toyota-4runner.org/3477672-post9.html
Jetboy is online now   Reply With QuoteReply With Quote
Old 03-25-2022, 09:35 PM #6
JoeBand's Avatar
JoeBand JoeBand is offline
JoeBand is on a distinguished road
JoeBand's Avatar
could always rent a flat bed trailer with the RV....
2016 Silver TEP "Zilla"
JoeBand is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 10:37 PM #7
Yep U-Haul doesn’t charge you mileage on things without a motor!
Old 03-25-2022, 10:58 PM #8
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The 4Runner has had Aisin Seiki Transfer cases for as long as it has existed.
The TRD models all have the Aisin Seiki VF2A.
02SE is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 11:43 AM #9
spartacus's Avatar
spartacus's Avatar
Rent a light travel trailer instead.
Old 05-16-2022, 11:59 PM #10
Cdezzz Cdezzz is offline
Cdezzz is on a distinguished road
I pretty much live full time in a Class A. When looking into my options, a trailer was the best option. I have a tilt deck trailer and it's a cake walk.
Cdezzz is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 06:06 PM #11
bill444 bill444 is offline
bill444 is on a distinguished road
In the past, some 4Runners with a manual transfer case shifter and neutral position could be towed four down albeit against Toyota's advice.
There are people on irv2.com that have towed this way for thousands of miles but maybe something changed over the years. Maybe I am thinking of a 4th gen.
IIRC, Toyota has been advising against 4 down towing for a very long time but it was possible on select models. The prior generation Lexus GX and 80 Series Land Cruiser come to mind as detailed examples I have read about.
bill444 is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 09:52 PM #12
Yes I have a 1993 FJ80 and I know that can be towed --------I may take that instead of the TRD PRO. Its just more truck than I need, and FJ80 only has 35,000 miles on it, so its not my first choice --- but the trailer rental could be a fall back.
alaska , experience , pro , towing , trd
V6 vs V8 Towing MPG soundmanlpte 4th Gen T4Rs 8 04-22-2019 02:47 PM
Towing... Lt. Classic T4Rs 8 07-19-2011 08:26 AM
Towing a 24-27' Boat with the V8 - What are you towing? rmd0311 4th Gen T4Rs 7 09-10-2009 08:36 PM
Towing the 08 SR5 V6 4WD T4R Spaceman 4th Gen T4Rs 0 02-16-2008 03:26 AM
