Old 03-26-2022, 08:22 AM #1
sunnah sunnah is offline
sunnah is on a distinguished road
Question Radiator Cover Clips Replacement
My 4Runner doesn’t seem to have the press down and open radiator clips. I have to force them open and basically all of them broke and now I have to replace them. But I would like to replace them with the ones I’ve seen that people just press down and it unlocks. Can someone give me the OEM part number so I may order the radiator clips thank you.
sunnah is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 11:18 AM #2
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
This style lasts longer. They are not necessarily intended to work more than once. These I have used on everything and never had an issue removing and replacing.
20PCS Radiator Cover Clip Fits for Toyota 4Runner Tacoma Lexus GX470 90467-08217 | eBay
Old 03-26-2022, 11:27 AM #3
Thank you. This looks like very similar to what I have already and they actually all broke when taking them out. Perhaps I'm not doing it correctly can you outline how to remove them and put them on exactly. Thank you.
Old 03-26-2022, 11:28 AM #4
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
This should be the OEM part. 9046707211
https://www.toyota-4runner.org/2920373-post2.html
Old 03-26-2022, 11:34 AM #5
Pavement Tested Pavement Tested is offline
Pavement Tested will become famous soon enough
Can confirm. I've got replacements on order for mine right now.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
Pavement Tested is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 01:07 PM #6
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I replaced the OEM ones with these from Amazon. They’re not push to release but I think they work better in this application.
Amazon.com: UNIGT 120 pcs Fastener Rivets Push-in Retainer Clips Compatible with Toyota Lexus Camry Corolla Body Clips with Fastener Remover# 90467-07201 (120PCS Combo Package) : Automotive
The original ones were breaking pretty regularly. At first, I was replacing with Toyota parts but started looking for a cheaper alternative and found these.
Edit: Another option that’s in stock. Decent reviews.
Amazon.com: GOOACC 100pcs Push-Type Retainer for Lexus Toyota Body Clips,Splash Shield Clips 90467-07201 Replacement Fasteners, Quality Nylon Push Rivets with Bonus Fastener Remover : Automotive
1000MPH is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 02:34 PM #7
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
I bought these off of rockauto for cheap. Work perfect.
DORMAN 963634 (963-634)
More Information for DORMAN 963634
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 10:53 PM #8
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Measure the holes with some calipers and order the right sixe (mm) from Amazon with the fork tool. Bag of 100+ is cheap enough.
You can replace them each time if needed.
BTW, one pulls the center pin up as far as it will go first to unlock it, then use a forked tool to pry the complete retainer out of the hole.
seatia is offline   Reply With QuoteReply With Quote
Old 03-27-2022, 01:39 AM #9
Just a interesting side note, the OEM pins don't pull the center up to release, you actually push them down to unlock em. Caught me off guard at first which caused me to break a couple before I learned the trick. Thats why I ended up buying extras. Center pin flush with the top of the pin is locked, pushed down a click passed that is unlocked.
clips , open , press , radiator , replace
Radiator Cover Clips Jeffrey_VB 5th gen T4Rs 17 01-24-2024 12:17 PM
Need Help w/ Tiny Part for 2000 4R (Rear Seat Back Cover Clips) T4R3G 3rd gen T4Rs 11 05-30-2023 08:33 AM
Replacement interior trim clips? Lolrax 4th Gen T4Rs 3 04-25-2020 07:26 AM
Replacement spark plug wire guides/clips? ki1022 3rd gen T4Rs 4 11-17-2015 12:42 AM
Cargo Cover Clips? Snesley Wipes 4th Gen T4Rs 9 01-21-2015 10:59 PM
