Old 03-28-2022, 10:20 AM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
Yes another 2021 LED headlight question!
Hello everyone,
I know that there are many posts about this already. There is also one that is 30 pages long! I read all of those! :-D I just want to make sure before order these.
I have a 2016 limited. I would like to know if I can just buy none limited 2021 LED headlights part number ( 81070-35600 ) (81140-35610) and swap the connectors. I understand the DRL and high beams wont work right if I go to Bi-LED OEM that comes with limited and TRD Pro. I have two questions:
1- Will my DRL and high beam work as designed if get the regular (none limited) OEM Led headlights?
2- I am planning to swap the halogen high beam bulb and use xenon depot DRL harness on OEM 2021 headlights to match low beam color . Will this setup work?
amir_gh is offline   Reply With QuoteReply With Quote
Old 03-28-2022, 10:57 AM #2
osugsxr osugsxr is offline
not 100% sure if the 2021 are low led and high halogen (non pro / non limited models) , someone on here mentioned that 21 is led low/high for all models. If thats the case you would need the 2020.
In my 17 SR5 prem. I think I have the 2020 headlights non pro/limited, with the led low and halogen high. It was a simple pin connection swap and everything works as it should. As for swapping the halogen bulbs out yes it ll work
Old 03-28-2022, 11:15 AM #3
amir_gh's Avatar
amir_gh's Avatar
You're correct. I meant to write 2020. Where did you get yours? Can I get the part number?
Old 03-28-2022, 11:18 AM #4
picked them up off a forum member here. I'd recommend checking secondary market for them. I've seen a few pairs from $250-350 range (FB market, offer up etc.) As for the part number not sure of that but from the dealer I think it was $900-1000 for a pair during sales.
Old 03-28-2022, 04:09 PM #5
amir_gh's Avatar
amir_gh's Avatar
I should have bought the OEM at first.
Old 03-28-2022, 04:24 PM #6
jojotheduck jojotheduck is offline
jojotheduck is on a distinguished road
Just swapped a set into my 2020 SR5 today. Pretty painless. Bought a like-new set off FB Marketplace for $300.
jojotheduck is offline   Reply With QuoteReply With Quote
Old 03-28-2022, 09:28 PM #7
amir_gh's Avatar
amir_gh's Avatar
I cant find anything off of the FB Marketplace :-(
Old 03-28-2022, 10:10 PM #8
Keep an eye out. I had to check every couple days for a few weeks before one popped up. I've seen two in the past 4-6 weeks.
Old 07-26-2022, 07:54 AM #9
bronco.si's Avatar
bronco.si bronco.si is offline
bronco.si is on a distinguished road
bronco.si's Avatar
Are you looking for 2020 headlights?
bronco.si is offline   Reply With QuoteReply With Quote
Old 07-27-2022, 08:40 AM #10
amir_gh's Avatar
amir_gh's Avatar
Already got them. Thanks
drl , high , limited , oem , work
lifting 2021 venture with kdss question Gouranga 5th gen T4Rs 8 02-25-2022 11:11 AM
2021 Audio System Question josephp732 5th gen T4Rs 0 09-19-2021 01:44 PM
Quick Question - Do Pro’s have footwell lighting like limited? Particularly 2021 Pro matoolie 5th gen T4Rs 4 01-23-2021 03:15 PM
Question about 2021 standard LED headlights. Redsoxx1918 5th gen T4Rs 17 10-29-2020 05:53 AM
99 headlight question atalarico 3rd gen T4Rs 10 11-16-2017 01:36 PM
