Old 04-02-2022, 11:21 AM #16
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
There are a lot of things I want to modify but I need my tuner!!
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 11:32 AM #17
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Originally Posted by 1jzgte View Post
TRD Intake Flow Accelerator Install | Toyota Tacoma | Adventure Bike Basecamp Build| FatBike - YouTube
here's what i did w/ my scoopy bernoulli thingie
trd air flow accelerator
Heck yeah! Awesome video and information. Thanks I was unaware of this product.
Old 04-02-2022, 12:09 PM #18
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
Originally Posted by Jakeepoo3 View Post
I don't know anyone like that either. I suppose that's why governments think catalytic converters are necessary. They should make everyone get a license for understanding and maintaining their machine.
whoa whoa.. im grateful for cat converters... we'd all suffocate on the roads without them... fumes from burning gasoline is toxic as F
You wont need to tune anything because the MAF has fairly loose tolerances to accommodate most air, humidity, altitudes etc etc.. if youre not throwing a check engine light you're most likely fine..
oh adn as for the TRD accelerator.. dont expect gains of any sort other than noise.. i just messed around w/ it because it was a cheap experiement
1jzgte is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 12:25 PM #19
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
There is a front facing flat funnel like air intake for, subaru's?
Sits on top of the radiator.
Seems like a couple guys have done it.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 04:37 PM #20
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I'm not sure the MAF would be significantly affected by the snorkel to be honest with you?
Throttle body/engine volumetric efficiency determines how much air the engine can physically suck into itself. The MAF will calculate how much air is going through the intake tube itself post air filter. As long as the air coming into the actual air filter box is roughly similar to what factory expectations are (which I don't entirely see being an issue with a properly designed snorkel) then the MAF should be reading within it's expected ranges. While turbulence and air velocity might be affected pre-filter, it should smooth out going through the filter and the actual intake air tube where the MAF is installed because those are controlled spaces.
If it isn't reading correctly then you'll set a DTC for some MAF performance issue as the vehicle will try to correlate the MAF signal (input) with it's expected load/work and monitor it's AFR and O2 readings (output) to make sure it is working within it's desired fuel ratios and efficiency parameters.
I don't think I've heard of anyone in the 4th or 5th gen forums needing to "tune" their ECM for a snorkel install unless they were going forced induction? But I haven't been around as much as I used to be so I guess I could have missed that?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-04-2022, 02:54 PM #21
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
https://www.youtube.com/watch?v=wv7-BbTmueo
This would probably be the cheapest option to get rid of the stock half cone piece. Not sure it would help the amount of dust/debris though. You'd really want a snorkel for that
Old 04-05-2022, 12:30 PM #22
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
This is what i was talking about, could not remember who made it before.
Ram Air Scoop - Volant Performance
Is a couple threads over on TW, peeps seem to like it.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 04-05-2022, 01:38 PM #23
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Thanks for the information. The throttle body interacts with air but has no idea what it is.. it receives several electric signals in the form of voltages and resistances from multiple sensors. The MAF interprets the physical properties of the air. Volume, temperature, density.. then the throttle body operates accordingly. The brains are engineered specifically for the way the truck was factory built with set parameters. These are strict parameters and slight variations in the signal make big differences.
The location of the MAF downstream of the air filter results in the air flow being normalized by the filter. The snorkel will make no measurable difference in the MAF readings or the performance. Nor will anything you do to that intake area on the dirty side of the filter make a difference if it doesn't restrict it significantly or move the intake into the engine bay where the air temps would be higher.
A set of baffles like the OEM fender liner to deflect mud spray away from the intake port in the fender would be another option. Toyota designed it the way it was for a reason.
Old 04-24-2022, 08:23 PM #24
Jakeepoo3's Avatar
Jakeepoo3's Avatar
That's cool! I jacked my hood up in the forest so maybe I'll get the scoop hood although I like the flat one. Not much mud seems to make it in that area hmm 🤔 fluid dynamics is more complicated than most people think.
Old 04-25-2022, 02:58 PM #25
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
You are way over thinking this. First, the flow post filter will be effectively unchanged in terms of laminar/turbulent flow. Second, this is air, not water or more viscous fluid, Adding a couple feet and turns to the intake piping is going to change your pressure drop by like 0.01 psi... Third, the MAF sensor is just that, a sensor, and is capable of accurately measuring a wide range of flow @ varying temp, pressure, humidity, etc. Lastly, the ECU which takes the MAF voltage signal and numerable other variables to determine fueling is capable of operating in both open and closed loop and has short and long trims and will adapt ignition timing, cam advance, and fueling.
I've tuned a bunch of K20Z3's and am anxiously awaiting the capability for 20+ 4runners, but this is not a change that would concern me in the slightest. Pull the battery long enough to wipe the short trims, plug it back in and put it through it's paces.
Bmnorm2 is offline   Reply With QuoteReply With Quote
air , exposed , intake , mud , sexy
Help me plan new AC Duct routes! AntleredRuin Off Topic 2 03-14-2018 12:18 PM
Any alternative to the $80 Toyota intake duct? drmoreau 3rd gen T4Rs 26 10-27-2015 07:00 PM
Thinking out loud, hood duct/louver? Jonny Classic T4Rs 6 11-24-2012 01:58 AM
WTB 3rd gen rear heat duct Crashnrondo Want to Buy/Trade 1 05-29-2012 06:35 PM
WTB 99 T4R a/c duct from ctr dash ericdg16 Classifieds - buy & sell (no commercial ads please) 2 02-06-2009 12:26 AM
